lmdew
    153
Everything posted by lmdew
  1. I'd start with some good injector cleaner. If you pull your plugs, the color will tell you if one cyclinder is not operating as it should. Could be: - Plugs, Coil, Wires, Injectors, Fuel Pump, Air Cleaner.... If you just replaced the knock sensor, it may take the ECU a little while to fully reset.
  2. Do you have the spring pulling the clutch fork forward-released position? Tightening the clutch cable will put the TOB against the pressure plate which is not a good thing. You should have about a 1/4" of free play in the fork travel before the TOB and the pressure plate make contact.
  3. Remove the bulb from the dash and disconnect the ABS unit. Brakes go to the normal non-ABS function
  4. 95 2.2 is all I swap in. I've seen many 2.5 with the HG done, only a year later a rod lets loose because the bottom end was damaged by overheating. Hey, if you are doing all the work yourself and you know the engine was not overheated do the 2.5 HG. Forget is posted, good 2.2 are getting hard to fine. You should go for the 2.5
  5. Well it would help to know what year model and engine you have. But given what you said, I'd say you are: - Low on Coolant (leak bad Head Gaskets...) - Check the coolant when the engine is cold, is the over flow bottle up to the required level? Pull the cap, is the Radiator Full? - Check the overflow bottle for black oily stuff, a sure sign of a HG leak. - Get you coolant system pressurized - Get you coolant system checked for signs of Exhaust gases, NAPA sells the kit for $70 or so. - If all that checks, it could be the thermostat, water pump or plugged radiator. Has the coolant system been maintained?
  6. You need a good fuel pressure gauge to make sure its working correctly and the pump is putting out the required fuel pressure. The PS pump is a load on the engine. You may also want to check the belt tension.
  7. There's a ground that should go from the firewall pitch stopper to the trans, its about an 1/8" dia wire. Good size.
  8. If the hose you are talking about is on the back side of the intake down off the fuel lines, its the fuel pressure regulator. You should have a vaccum line diagram on the hood. Check it out. Yes, the codes are necessary, any good auto parts store will read them for free. Plugs, Plug Wires, Subaru or NGK only! Check the coolant overflow tank for signs of oil = Head Gasket leak. Remember the search feature of the USMB, you will find lots of good info.
  9. Sounds like a good plan. Yes you should only have 1 VSS on the manual trans.
  10. Pretty straight forward. Jack the car and place jackstands under Crawl under and unplug the 2 fans Disconnect the lower hose, with a bucket under to catch the fluid. You can do this at the thermostat housing or even remove the 2 bolts that hold the theromstat. Remove the generator and AC belt covers for clearance While it's draining, Go back to the top and remove the bolts holding the overflow tank Remove the bolts holding the fans Remove the top radiator hose Remove the Transmission hoses Remove the top radiator support and pull it straight up. Reinstall in the reverse order. Search for Burpping the coolant system on the USMB, you want to make sure you get all of the air out when you put the new radiator in. PS, this is a great time to change all the coolant hoses and flush the system.
  11. It was the hub bearing! Sweet. Once I pulled the brakes and drive shaft the roughness of the bearing was very present. Used Hub went in and in about 30 minutes I was done. Clutch change and it will be back on the road. $400, for the Legacy with 140K. Nice
  12. It would most likely cost less to replace the complete rack with a good used one. Lots of low mileage ones out there. A good shop should be able to tell you if it's the inner or outer tie rod that is loose. Replacing the rack is not a bad job.
  13. Must be non - stock configuration. All of the doors I've removed have always been bolts going into the frame and the door. You could always pull the hinge off the door side instead.
  14. 10 or so. 96-98 Oubbacks, Legacys, autos, manuals.... Just make sure you have the correct EGR valve configuration and that the single or dual port exhaust match or you get the y pipe to go along with the engine.
  15. I think the speedo sensors are different. The 90-94 has a cable, the 96 has an electronic speed sensor. I've put the electronic speed sensor on to the older trans and it works, but I don't know if it would work the other way. Gear Ratios may be different as well so match the rear diff.
  16. I love these swaps as well, but it's getting harder to find good low mileage 2.2 engines.
  17. Just those two screws. Hold the door handle out when you try to move the panel away. I go around the outter lip with a paint roller cleaning tool, its flat and sturdy and will pop all of the plastic clips out. Then you can remove it. It's easier with the window down. The keyless would be tucked up under the dash on the drivers side. I usually held in with a couple of zip strips. It's about 4" x 5" x 1" black box. Mine are GOH units. I think I have a used one with the wiring. Colorado Springs, CO USA
  18. It just pops out. It's held in by the grommet which seals the pump. Make sure you have good voltage to the pump before you pull it. You could take jumpers right from the battery to test it.
  19. Thanks, clutch and hub will be the plan. If the noise is still there, more troubleshooting will be required.
  20. I picked up a 96 that needs a new clutch for sure. The guy fried it by not adjusting the cable. It was as tight as could be, clutch not full in gauging. The pedal is all the way to the top before it catches, even after I backed it off to make it home. The shop he's been using for a long time said he also has transmission problems. The trans shifts fine and the noise sounds like a wheel bearing. The noise is still there when the trans is in neutral. The Passenger side front hub, I suspect is bad as the noise is the worst when in a left turn. Brakes applied the noise is still there. However, there is no freeplay in the hub when I have it jacked. Spins OK with the tire and wheel on. Poor test, I know. I'm thinking New Clutch, front hub and the normal required maintenance and it will be road worthy. Anyone ever have a bad trany bearing sound like a hub bearing?
  21. Complete hub is much easier and quicker. You should be able to find a good used one at a yard for under $50.
