153
Everything posted by lmdew
Spent some time in the yards on Sunday. It's a base Legacy Sedan. He hit a deer - hood, headlights, bumper, grill, radiator, AC condenser, fans and timing belt covers all needed. We pulled the radiator support. I pulled all the mechanical parts and a good hood. Still hunting headlights and the supports. He may have to go to ebay or www.car-part.com. So it goes. It will be back on the road.
I'm helping a friend who hit a deer put their 2008 Legacy Sedan back on the road. Headlights are listed as 2008 - 2009 Only. They have a plastic mount that the headlight attaches to. The 2005 has what looks like the same headlight but a metal support. Of course the bumper cover mounts are different. They are too new for me, but I was thinking if I swapped out the complete bumper, headlights, mounts the 2005 may work on t he 2008. Anyone confirm? Thanks, Larry
There are connectors on each side of the rear hatch behind the side panels. You need to get the hatch open to remove the side panels unless you want to destroy them. A local yard that you can go into is a great resource to pull the panels and see how everything goes together. Your meter can lie to you. Check out LOADpro. Every circuit has: Load Ground Power As said before get the diagrams and work through them.
Relay question
lmdew replied to 1197sts's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Where is your son? Someone close may be able to help. Many Bases also have Auto Hobby Shops. Some better than others. -
Impreza h6
lmdew replied to Gypsybaron3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
There is a 2 pin blue connector on the back of the Dash. I believe that is the speedo connection. I'd check to see if you have it on the gauge cluster and then use the wiring manual to find the best place to connect you VSS to it.
