153
Everything posted by lmdew
Oil Pump
lmdew replied to Subaru45895's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
No sealant on the pump cover, Gray RTV on the oil pump housing to engine block. I let it set 24 hours to ensure its cured. -
Use the search on the USMB and you will find tons of info. Yes the auto to manual is a good change and not to hard. Make sure the Rear Diff is changed as well so the gear ratios match. If you can find a complete car non running and then pull the trans and all the other stuff you will need that is best.
On the starter. Follow the + battery cable back. Check the Battery voltage, terminal to terminal and note it. Move the positive lead to the starter end of the terminal and check the voltage and record. Now have someone try to start the car, the voltage should not drop but .5 volts or so if the system/wiring is good. If it checks good there, go to the output side of the starter solinoid to the starter motor and do the same. If you are not comfortable checking the system, most autoparts places can check it for you or you can remove your starter and take it to a starter rebuild place and have them check it.
It would help with the YR and Model. The Legacy pumps are under an oval cover in the trunk or under the rear seat. The older DL... are under the body back by the tank. If you pull the fill cap and have someone turn on the key the pump will run until it builds pressure. The only sure way to check the output of the pump is to install a pressure gauge and check the flow rate. Is the CEL on?
Get a 97 - 99 Outback with a bad 2.5 engine and have a 95 2.2 engine installed. The 5 sp transmission is a much better option as most folks do not maintain the autos as they should and then the can't figure out why the trans failed at 140K when they have never changed the fluid. If you want to keep the 2.5, motor get a 2002 or later. The 3.0 are good solid motors as well and gas mileage will be about the same. 96-99 bodies and interior room are all about the same. Visit you local dealer and check some of them out then have your contacts go hunting for what you want.
The cam gear may be even harder. Soak it good with PB Blaster or Croil. If you lucky, the holes in the pulley are threaded and you can make a puller. If not you can tap the holes. Or very carefully put two large blade flat screw drivers behind the rim and work it out just a little, then tap it back. Keep on doing this until you break the rust free. Understand the crank seal is right behind the crank gear. I've seen the trashed and a new Oil pump needed.
You can move the crank and the cams to line the timing up you are not spinning at 3000 RPM as you would be going down the road. If you are turning things by hand and it locks up, STOP and turn it the other way. Put the crank in position, then the cams. Install the new idler pulleys, the new belt and then the toothed idler. Release the tensioner, then rotate the engine in the normal direction, at least 720 degrees and recheck the timing marks on the gears.
Yes Interference Yes most likely bent valves, but it would not hurt to check it a little further and see what the cause was. The Ebay Kits belts and pulleys are good. The only way to tell how much damage there is would be to put it back together and do a compression - leak down check or pull it apart. How many miles on the car?
