153
Everything posted by lmdew
Unplug the fuel pump under the seat, crank the car for 20 seconds or so to release some of the fuel pressure. You will need a 5/16" tee fitting, about 6" of fuel line. Go on the engine side of the fuel filter in the engine compartment and tee in the fuel pressure gauge. Hook up the fuel pump connector and crank the car over. You should see fuel pressure rise as the system pressurizes. I don't have the exact PSI but anything over 30 should be good.
I've done a few Timing belts and I've started making it part of the process to pull the oil pump and lock tight the screws, change the crank seal and Oil pump o-ring. The last 2 I've done 3 of the screws were backed out over a 1/8". I think once the threads have been cleaned and the screws put in with lock tight it should be a finial fix. Has anyone seen the problem repeat?
My Cruise stopped working a while ago. Today I was checking it out and the clutch switch was not being activated because the little rubber bumper on the brake box was missing. The hole for the bumper lined up with the switch pin so it was not closing the switch. 98 Impreza OBS but I suspect others are the same.
I didn't read all the pages, but I'm having P0303 on my 98 OBS. I have found #3 not firing. I back probed the injector plug to check for voltage, the book says 12 volts minimum. Voltage is always there the ECU supplies the gound to complete the circuit, but you'd need an O scope to see the voltage drop. The harness is not to bad to change, the manifold comes off and then you can swap it out. I may have a 2.5 harness off a 98 Legacy. I'm in COS. Larry
I pretty much have it down to #3 not firing due to lean fuel. I thought I had it a few times when I did the following, but the problems comes back on #3 cylinder. Cleaned all the Engine Connectors Cleaned the MAF and then swapped in one I had (seem to help the most) New Subaru Plug wires, no change Pinch the fuel return line and the RPM increases some so I'm going to tee in a pressure gauge and change the filter. My Manual says 2.6 to 3.3 PSI for fuel Pressure is that correct? Full system voltage at the Injector 14.2 Volts engine running. When I have the rough running at Idle pull the #3 injector plug has no effect on the RPM. The plug is white as can be, lean. More after I test the fuel pressure. Thanks for the ideas, Larry
Glad to see the USMB is Back! 98 2.2 Impreza 5 sp 262K with about 160K on the engine. It's been running rough for a while, noticeable at idle, with more shaking the a smooth Subaru engine should have. Until the last few days, there have been no codes over the last 8 months I've noticed this. The codes posted P0301 and P0303, miss fire on 1&3. I've checked and done the following to get it running right. - New NGK Plugs, - Air Filter - Swapped Plug wires - Fuel System Cleaner - Checked for vacuum leaks None of these fixed the problem, although slight improvements were noticed. This has been a very slight problem until the last day or so. With the codes showing, I pulled the plug wires one at a time, all produced a drop in RPM. I pulled the injector plugs one at a time, #3 produced little or no change in idle. Ohm the injectors, all were 11.7 Ohms. I had another coil, so I swapped them, no change. I had a set of 2.5 injectors, so I swapped them, slight change still rough. I can hear a Pop Pop in the exhaust. I'm going to do a compression test and check the timing marks tonight. What else am I missing? Thanks, Larry
If you have a tile nipper, just put a few layers of masking tape over the sharp edge and then it will work for the clamps. I'm in aviation, so I also have used safety wire instead of the clamps. 90 degree bend on one end and then wrap it the wire around the boot 8 times or so, going on top of the wire you bent to 90. Pull tight and twist the ends. I never had one fail or grease leak out.
I have never been in the salvage business, I do try to help folks out when I can. Check the Denver Craigslist or http://www.car-part.com
Here are the things I look for, how about you? Accident something that took the car out of service, most likely was running down the road (good engine and Trans) No accident (auto Trans) most likely the trans went Mileage, the lower the better Coolant overflow bottle for oil/black stuff = Head gasket leak Pull the engine drain plug (most yards drain the oil) some oil will be left in the pan, cleaner the better and no metal in the bottom of the pan when you stick your finger in. Turn the engine over, good compression if compression seems low, make sure the plugs are tight. Pull the plugs, clean and a even burn on all is great Pull the side timing belt covers, align the cam sprockets the timing marks should line up. Newer belt is super Overall condition of the car, cleaner the better I haven't had a bad motor yet, but have pull some that were miss timed and the timing had to be reset. The crank pulley is usually off (they used the front arrow instead of the tooth tick mark)
