153
Everything posted by lmdew
Yes, you have to lift the engine. If you pull the exhaust down and remove the engine mount bolts you can jack up the engine from below and then put blocks under the engine mount bolt to hold it up. I'd also remove the rear upper dog bone link. RTV is the seal for the pan, make sure the surfaces are clean and give it 24 hours to cure.
VIN Check Please
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
OBS is doing great! STI Struts, Rear Disk, GT Wheels and Tires. Yes, I don't know why the DMV could not find it in CO. The Carfax should show history of what state/states it was registered in and the current State. If someone can run this it would be great. I'm still locked out of the monthly unlimited checks. -
Water De-carb
lmdew replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I use the Off bug spray bottle, the thin plastic one, pull the pump nozzel off and there is a 1/8 or so straight fitting, that hooks to the vaccum line perfect. I keep the bottle level or hose up slightly and let the vaccum pull the water out until the bottle is sucked flat. Works great. -
It's Easy to remove and the Airbag does not have to be replaced. Make sure the steering wheel is straight ahead before you start. Disconnect the battery for at least an hour to be safe Look on the side of the steering wheel you will see two bolts which hold the airbag on, loosen them, they are captive so they will not come out. Pull the airbag off the steering wheel and disconnect the wires Disconnect the other wires that may be there for the cruise control. Remove the center nut and use a puller to pull the steering wheel. Put it all back together.
If you have your old cable, pull the center core and put it in the drive coming off the trans. Move the car and make sure its rotating, if not it could be a failure of the extension or the internal drive gear. (I thought the 97 had an electronic speedo, but you have a cable). If its not turning, pull the drive extension and then look down the hole as you move the car and see if the speedo drive shaft is turning. If it does not turn, its the drive gear in the trans. If the trans was rebuilt, I'd go back to the shop.
