153
Everything posted by lmdew
That's what I was thinking. I pulled the switch, destroyed it getting it out and put in a good one I had. Same results. I have power at the AC Switch both into the switch and out when the main control plug is unplugged. When I plug the main connector back in, the output voltage dropps to 0. I have to get the correct wiring diagram for this car. I have the same diagram you have from the wire codes you've given me and none of the wire colors match the car. Strange! Thanks for taking the time to help on this. Larry
I have a 98 Impreza Wagon that the AC will not run on. The following has been checked: - AC Switch light comes on when pressed - Fuses are good, relays are good - Jumping the pressure switch does not turn on the Compressor - The radiator fans do not come on with the AC selected - If the relay contacts for the compressor are jumped the compressor kicks in - There is no power at the coil for the AC relay The relay wires are as follows: Coil: Green-Red stripe and Brown Contacts: Green-Orange stripe and Blue I have several wiring diagrams, but none of them match up. It looks like the coil gets power directly from the switch, so pulling it and checking power there will be my next step. It would be Great to have the correct diagram. Thanks Larry Lmdew@hotmail.com
I've put WRX and STI Struts on my 98 OBS and my Daughters 93 Impreza Sedan. Yes you do have camber out of limits unless you get camber bolts or use Subaru Front camber bolts and mod the strut and knuckle. I left mine with the camber out of limits a degree or so and have not had a problem with either car.
Fixed. Just had to remove the bottom sill trim, loosen the two bolts and give it a wack with the board and hammer. I moved it back about 3/16" and it no longer rattles. Solid as can be. There is a little adjustment in just the latch plate, but I needed more. Anyone have the cure for the Rear hatch rattle on a 98 Impreza. There does not seem to be much adjustment in the hook and none in the latch. The bumpers are in good condition as is the seal. Am I missing an adjustment point, Thanks, Larry
Found a nice set of 15" Dodge Snow Flake Wheels (5 x 100) at the best yard in Colorado Springs. These wheels are set up for the large flanged lug nuts Dodge uses, and putting the standard Subaru lug nuts on puts the lug nut way down in the tapper of the wheel. Has anyone found a lug nut with the large flange and the correct Subaru thread to make the bolt up a little better? Thanks
The STI Struts are great! The backs will bolt right up using the Impreza Springs and top hats. The STI Springs are tappered and will not fit the OBS top hats. (Note, I think you could get the older legacy wagon top hats that have the tappered springs and then the STI springs would work.) The fronts are a little more work. The top hats will bolt right in, but the knuckle mount holes are off by about 3/8" and the mount is wider than the knuckle. Here's what I did to solve both problems. - Remove the old struts and cut off the mounting plates. - Drill out the spot welds so you can seperate the inner and outter plates. You will use the inner plates. - Clean everything up and remove the paint along the edge for welding. - Insert the plates you cut off inside the STI struts mounting channel. - Use the top adjustment hole as the master and align them with the existing hole. - Clamp the new plates to the struts with the center line of the lower hole aligned. - Weld the plates in place along the outter edge. There is no reason to weld the inner edge and this also reduces the heat put into the strut. (Get them tig welded to reduce the heat transfer) - Drill out the lower holes. I used an old knuckle as my clamp and alignment jig. It worked well and I drilled a little undersized so I could file the new hole out to the existing hole in the old plates. - Paint and then apply silcone sealer to all open seams (the ones you did not weld). -Bolt them up and get an alignment. The rears gave me a little lift (1/2 - 3/4") The fronts a small drop, less than 1/2". Rides great!
