153
Everything posted by lmdew
I believe I have confirmed its the ECU. I pulled connector B136 pins 7 (white +) and 20 (black -) which are the O2 sensor input wires. The ECU still sees 3.8 volts and reading the O2 sensor direct its 0.001 to 0.8 volts which is right in the range is should be. How long is the Federal Specifaction Emissions Performance Warranty period? I thought it was 8 years, but have not been able to confirm it. I'll check with the Dealer to see if the ECU has any recalls. Looks like its a new ECU.
Ecu diagram
lmdew replied to marshy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I'd try over at http://www.nasioc.com in the performance form. -
I disconnected the O2 sensor in the engine bay. It worked fine if read directly. At the same time the ECU still had 3.8 volts. I pulled the ECU cover and looked at the circuits and no defects noted. I'm going to try another ECU or pull the O2 sensor wires at the ECU plugs and then see if the ECU still has 3.8 volts. That will confirm its internal.
ABS light
lmdew replied to dssenne's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Without it you will not have ABS and the light will be on! -
ABS light
Could be if the new axle did not have the ABS sensor ring or the wires got damaged. -
If the trans drive spins without moving the car, the gear is trash. You can not pull the shaft up, as it has a c-clip on the bottom. You will need to pull the passenger side axle, the stub shaft, the bearing housing (make sure you mark it for proper bearing load) and then you can get in and change the gear/s. Not an easy job, I'd get a new outter seal and the oring for the bearing housing. Make sure you do not cross thread it when you put it back in.
The dealer is trying to work things out. The Ebay Manager, Jason was goint to drop the car for me at MHT, but then the owner put the brakes on that Idea. Now I have to wait overnight, 12 hours of drive time lost. The dealer closes at 6 and I do not land until 6:45pm From NASIOC I have a possible ride and links to local transport so I can get to the dealer. Then its just the 2000 mile trip home. Lifes a trip, enjoy the time you have :>) Thanks to All, Larry
I think the temp sensor and fan switch are different. Look at the R/H intake manifold. You should see two sensors. You can put the ECM into D-check green connectors if my memory is correct and the fans should cycle. If they are doing that the wires should be good. Have you burpped the system? If there is air in the system it will cause problems. Good luck. Larry
