157
Everything posted by lmdew
Friend's Daughter living on her own sent a text the other day. Car dies. Did it several times. I told her to come on over. Well it took way to long. Turns out it died several time, started smoking. I asked what the temp gauge was showing. I got a pic of it pegged. I eneded up going down the road with coolant. I filled the system, it took almost a gallon. No leaks noted. We drove it the last mile to my place. I pulled the codes: P0325 - Knock Sensor. I tried several of my used ones but code keep on coming back. Ordered a new one. P0116 - Coolant Temp Sensor - lack of coolant I suspect P0420 - CAT Effiency - Car has 212K on it so it's not much of a worry. I reset these all the time. P1507 - Idle Air Control. I cleaned the valve, the seal ring looks good. Also added fuel system cleaner. The P1507 came back, I've checked the vacuum lines and connections. They look good. Any thoughts?
Spent some time in the yards on Sunday. It's a base Legacy Sedan. He hit a deer - hood, headlights, bumper, grill, radiator, AC condenser, fans and timing belt covers all needed. We pulled the radiator support. I pulled all the mechanical parts and a good hood. Still hunting headlights and the supports. He may have to go to ebay or www.car-part.com. So it goes. It will be back on the road.
I'm helping a friend who hit a deer put their 2008 Legacy Sedan back on the road. Headlights are listed as 2008 - 2009 Only. They have a plastic mount that the headlight attaches to. The 2005 has what looks like the same headlight but a metal support. Of course the bumper cover mounts are different. They are too new for me, but I was thinking if I swapped out the complete bumper, headlights, mounts the 2005 may work on t he 2008. Anyone confirm? Thanks, Larry
There are connectors on each side of the rear hatch behind the side panels. You need to get the hatch open to remove the side panels unless you want to destroy them. A local yard that you can go into is a great resource to pull the panels and see how everything goes together. Your meter can lie to you. Check out LOADpro. Every circuit has: Load Ground Power As said before get the diagrams and work through them.
Relay question
lmdew replied to 1197sts's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Where is your son? Someone close may be able to help. Many Bases also have Auto Hobby Shops. Some better than others.
