153
Everything posted by lmdew
PYE I have your drive shafts for your trans swap. I pulled them from a 92 Legacy Sedan. Good Shape, I'll also send the diff input so if your 96 is different, you can swap them over. That what I did on my son's RS Trans install. Send your shipping address and email. Lmdew@hotmail.com Lost your email.
need radiator
lmdew replied to supergn6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Single core, which is more cooling than you should need if the system is in good shape! -
need radiator
I have one for an Outback Sport, it may fit your as well. $50 plus shipping. Lmdew@hotmail.com. I can send some pics when I get home. Aftermarket metal end caps, no plastic. -
Keep it simple: Is the fluid properly serviced? Install the FWD fuse, does that help? If the fuse does not help drop the rear section of the rear drive shaft that should get rid of the torque bind but gas mileage will be bad! Used Transmission will be less! Oil leaks are easy if you can do the work.
I am back
lmdew replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Green tan interior, but they are mostly trash. -
I am back
You are welcome to come and grab parts off the 93 Legacy that is going to the crusher next week. Its down at the old COS airport. I'll be back in town Friday. -
CV Boot
lmdew replied to AussieIan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Balance will be a concern. I use 0.320 safety wire about 6 wraps and do them that way. Pull it good and tight and it will seal and not damage the boot. -
Brakes, help?
lmdew replied to eagleb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Why do you think the rotors need to be replaced? You can turn them at least once. If they are trash, check the local yard I find like new ones all the time. www.nasico.com has the WXR stock brakes that the go fast guys are selling cheap and there is always Ebay for cheap parts. -
Its in the tail shaft of the Transmission. Put the FWD fuse in the holder (engine compartment) and see if it goes into FWD. If not the solenoid or wire is bad. You can check it from the trans plugs in the engine compartment, but I forget which terminals are for the C-Duty. Search C Duty Solenoid and you will see some great pictures of the parts location. I would not drive the car to long without getting it fixed. I purchase one that took out the front CV joint as it is in FULL AWD All the time.
