153
Everything posted by lmdew
You can either pull the engine or the trans to get at the oil seperator plate. No the dealer would not have done this as it would add to the cost of the front engine work. If you pull the engine for the HG or clutch if its a standard trans, then yes a good shop would do it. You may want to try the WRX seats, lots of them at nasioc.com site. As for the HG if it isn't broke don't fix it. You may get past the inspection if you clean everything down real well, you could even stick a pie plate up there to grab the oil. Just make sure you do not run out of oil.
Yep, flushed it all, I pull the upper radiator trany coolant hose, put another hose on the fitting and let it pump out the old stuff as I'm adding new fluid. It works great. This is after a drain and fill of course. 177K, on the car in otherwise good condition $600. I figured at that price I could replace just about anything. I'll do some more checking today, may just be the C DS.
I picked up a 97 2.2 Legacy Auto. The guy thought the trans was shot, but I found the passenger side outer CV joint cage in lots of parts. The boot was still good, but the shaft could turn inside the housing. I replaced the half shaft and its working. There is some torque bind. I flushed the fluid and will give it some time. I'm also going to see if the FWD fuse makes any difference. Has anyone ever seen a joint fail due to torque bind? Thanks
They drop right in and you can't get a better engine. CCR has a great product and are very good people to work with. I've done 4 of these swaps and I'm happy with the results. I grab the purge canister from a 90-95 and install it in the engine compartment, but you can also use the stock one. If you need the canister, just hit the local yard. It takes about a day to do the swap. Less time if every nut and bolt is not rusted tight.
Carfax Please
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Thanks, Larry -
Sometime the VSS on the trany goes, but these have problems with the speedo head. If the CEL is not on and the cruise still works the VSS is sending the signal out. Its most likely the speedo or the connections. Try pulling the gauge cluster and remove the screws holding the speedo in. Clean the contact and replace the screw. Put it back in and see if it works. I've fixed a few this way. If you need a new gauge cluster let me know I have a spare.
Well, it comes down to how much you have in the car now, how long you are going to keep it if you fix it and what you would do to replace it if you did not fix it. With a bad motor, these go for $1000-2000 depending on condition and demand. If you are going to keep the car for 3-5 years then a few thousand for a rebuilt engine would be worth it. Used engines can be had with 30-90 day replacement, but they will just give you another engine. If you are not doing the swap yourself, you are out the labor cost.
