lmdew
Everything posted by lmdew
  1. Send me a PM or call 719-200-2973. My son has two spare starters in Fort Collins for a Auto Trans. He'd be happy to put one in for you. Later, Larry
  2. Yep, that was my plan. I'm going to disconnect the sensor from the harness and see what the ECU has vs the output of the sensor. I just need the time to get there. Thanks for the info! I'll update when I get it checked.
  3. I probe the splices of the new sensor with my Fluke 83. I can also see the voltage with my computer through the OBDII connector. Yes the voltage is way high. When I checked the old sensor on the bench with the torch it read .5 volts.
  4. CEL P1133 The front O2 sensor on the 99 Impreza I picked up is steady at 3.8 volts. I put in a new sensor and got the same results. All the wiring seems to check out. Blocked CAT???? It runs fine, just made a 2000 mile trip. The CEL is for the front bank no response. Ideas? Thanks
  5. Get the codes from the ECU. Is the CEL on? It could be anything!
  6. I have 3 good used units. $40+shipping. Lmdew@hotmail.com
  7. It's splined on both ends so unless you took it off your steering should be OK. If you pulled it, the steering wheel may be off center but no alignment problems. Tight is good, I've never seen one back off.
  8. I have a good set of senders and a pump, your's for $40+shipping from CO. Lmdew@hotmail.com
  9. If the trans drive spins without moving the car, the gear is trash. You can not pull the shaft up, as it has a c-clip on the bottom. You will need to pull the passenger side axle, the stub shaft, the bearing housing (make sure you mark it for proper bearing load) and then you can get in and change the gear/s. Not an easy job, I'd get a new outter seal and the oring for the bearing housing. Make sure you do not cross thread it when you put it back in.
  10. The drive may have failed in the trans. Check to see if the output is turning as the car is dirven. Plastic gears in some trans.
  11. The dealer is trying to work things out. The Ebay Manager, Jason was goint to drop the car for me at MHT, but then the owner put the brakes on that Idea. Now I have to wait overnight, 12 hours of drive time lost. The dealer closes at 6 and I do not land until 6:45pm From NASIOC I have a possible ride and links to local transport so I can get to the dealer. Then its just the 2000 mile trip home. Lifes a trip, enjoy the time you have :>) Thanks to All, Larry
  12. I'm flying into MHT on Friday evening. I have to get down to Subaru of Nashau, NH. Other than taking a taxi, I have not found public transportation. Anyone close by? I'm picking up a 99 Impreza to drive back to Colorado. Thanks, Larry Lmdew@hotmail.com
  13. I think the temp sensor and fan switch are different. Look at the R/H intake manifold. You should see two sensors. You can put the ECM into D-check green connectors if my memory is correct and the fans should cycle. If they are doing that the wires should be good. Have you burpped the system? If there is air in the system it will cause problems. Good luck. Larry
  14. Back off the tie rod jam nut. Remove the tie rod (TR) cotter pin and nut. Unscrew the TR end. Count the threads or measure so you can reset the toe. Remove the outter boot clamp. Slide the complete boot off. Clean the rack end as much as possible. Reverse order and your done.
  15. Could be, make sure all tires are the same and have the proper pressure. Try putting in the FWD fuse and see if the FWD light comes on and the problem goes away. If so flush the trans. I have an extra shifer assy if you want it. $20+shipping from CO. Lmdew@hotmail.com
  16. I picked up a 93 Impreza 1.8 153K. It runs fine but the coolant was full of oil, 99% oil. The oil does not have coolant in it, its clean as can be. Initially, I thought one of the quick lubes missed serviced. The PO said, that was not the case and the engine was using oil. They kept it full of Oil. Has anyone seen this? Head Gasket? Thanks, Larry
  17. I agree, for now its working and when I get time I'll look into it further. Thanks for the links and info. It was pulling 18A on a 15 amp fuse. Thanks Again.
  18. Strange, I pulled the other two wires and put the turn signal wire back in its connector. The fuse blew with only the turn signals. I pulled the turn signal wire and jumped pulled power from the another 15A CB and it works fine. I watch it and see what happens.
  19. I found the correct wire for the signals, bottom aft connector on the kick panel fuse box top aft wire. If I power it from another fuse the signals work fine. By taking apart another fuse box, I found two other wires coming off that CB. Now I just have to figure out what the go to. Thanks for the suggestion. Larry
  20. I have a 93 Turbo Legacy Sedan that the turn signal fuse blows as soon as the key is turn on (top aft fuse on the drivers kick panel). Funny thing, the emergency flashers work just fine. I need the FSM wiring, as the Michell's and Chiltons I have seem to be wrong. I've disconnected the turn siganl switch - fuse still blows I've disconnected the Emergency Flasher Switch - fuse still blows The only way I've been able to get it to stop is to disconnect the connector coming off the fuse block, top aft. If you have any thoughts, please send the advice and or wiring diagram. Thanks, Larry Lmdew@hotmail.com
  21. Before you open it up, I'd contact the shop and see what they will do for you. If they are a good shop, they should stand behind their work. If it was a part failure, that they could not see, they would not be at fault but they may still help you some.
  22. Any problems putting a 93 2.2 into a 93 Impreza auto trans? Is the y-pipe the same? I think everything else is a straight cross. Thanks
  23. Look at the rollers on the track. I'd have someone hold the window and pull the motor out. Then hand lower and raise the window to make sure it is working without binding. When its good, re-install the motor. You should be able to check the motor while it's out as well. Its just a 12vdc motor.
  24. I have a complete 99 dash cluster, $75+15 shipping. Lmdew@hotmail.com. There 77K on it I think.
