153
Everything posted by lmdew
Cam and crank seals along with the oil pump oring are also a good idea at that mileage. Is the water pump leaking? There is no need to change the pump unless something is wrong with it or you are in there and it has 100K on it. If the pump is still working and you watch for coolant level and your temp gauge you will see the failure before it has any - effect.
Speedo is common. Try pulling the dash and pull the 5 screws that hold the speedo in. Clean the circuit contacts and put the screws back in. These are the connections to the speedo as well as the hold-down screws. The Vehical speed sensor could also be causing your speedo and trans problem. Get a new or good used one and replace it. Its on the right side of the trans about 10" back from the engine.
I pulled the VSS to drive it by hand and check the speedo and the VSS broke in two. After installing a new one and tightening the screws that hold the speedo to the dash all is Fine. For owners with this problem, it may be worth a try to remove the dash and then one at a time remove clean and reinstall the 5 speedo screws.
Flex Plate Bolts
lmdew replied to lakroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
1/4 drive ratchet with 6 point socket, then slip a box wrench over the ratchet handle to extend the lever. It fits in the tight space and gives you the leverage you need. -
The belt if off, I bet! Make sure you are using the correct timing mark on the rear of the crank pulley, not the one on the front. The same thing happened on my brothers Legacy 2.2. Pull it back apart and reset the timing. Good Luck! Using the factory belts with the painted timing marks makes it much easier to time correctly.
Blown Engine
lmdew replied to Transam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
CCR Engines in Denve CO is the best rebuilder in the US. I get to SLC every once in a while, I could check it for you if you are in no rush. You might also look at http://www.nasico.com and Rocky Mountain Club and put a post there. Lots of SLC Subaru guys. Thanks for you Service! Larry (USN Ret.) -
I've done two of these 98 Legacy Outback 2.5 swapped to a 2.2 from a 95. Both were Outbacks had standard transimssions so I had good performance with the 2.2. Yes, the 95 2.2 is a direct plug in. If you swap over the flex plate from your engine, that will bolt up to the transmission fine. Make sure you do NOT pull the torque convertor out of the trans at ALL. Keep it fully engaged back into the trans when you pull the engine. I also pulled the vapor canster from the 95. The 97-98 has it in the tank area, but you can add the one up front and then you only have one vac. line to plug. If you know the engine is good, I'd do the T-belt and water pump up front. If you think it may need other work, just put it in and make sure it works before you put any more money into it. Its not hard to do those items with the engine installed. Good Luck
Most likely you have an air lock. Drain the system and then jack the front as high as you can. Fill the system through the top radiator hose slowly! When its full, put it back on and continue to fill with the bleeder plug removed! Start the car and let it warm up, burp the collant by pinching the top hose often. Do the warm up cool down cycle several times. The system should be air free! Take it off jacks
