Everything posted by lmdew
Axle Replacement Quagmire
lmdew replied to akeven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMost likely rust build up which may have caused the damage. I've had this problem before on east coast cars. Get some good P-oil and spray it down. Clean the splines on the old axle and work it in and out from the outside. That will push all the junk out of the splines. You may want to remove the inner seal or put a rag in it to keep this junk out. You could do this with the new axle as well, just make sure you get the splines cleaned out before you install it. It takes some time, but it has worked for me.
External tranny cooler - where to get one?
lmdew replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXVisit your local junk yard and look at the old trucks. Lots of great heavy duty coolers < $10 usually. Just make sure you clean them out well!
Speedometer died
lmdew replied to Tommymc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe gauge pod is easy to pull, but tight. There are 4 connectors at the back. Lower the steering wheel all the way. Pull the 4 screws from the trim. Pull the 4 screws from the gauge pod and pull it out a little. Remove the connectors, 3 along the top, one in the back. Make sure the screws holding the speedo head are clean and tight, these are the connection points from the circuit board. If you need a gauge pod, let me know. Larry
225/70/15 tires on an Outback?
Has anyone put 225/70/15 tires on standard Outback rims? I think they would work, the fit will be tight in the wells. If you have this combination and they are working please let me know. Standard struts, no lift.
Help, need to fix tranny filler pipe!
lmdew replied to subieman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWas the o-ring on the pipe? I'm not sure, but if you drop the pan, you may be able to get at the screw. If you can not, then the JB weld would work and you could make sure any extra JB did not get into the pan. Down side to this, you will not be able to remove the pipe if you have to and vibration may cause the JB to fail at sometime. This car has been not so nice to you!
how's your Outback mileage?
lmdew replied to mrfeh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow's the plugs look? Could be a bad temp sensor is causing it to run rich. Lots of sensors affect the gas mileage. If the plugs look good, make sure your brakes are not draging and the wheel bearings are good.
'95 Legacy Wagon -- wisdom on new wheel/tire sizes?
lmdew replied to Rob Kuhlman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWatch the nasioc.com site the guys sell the wrx wheels and tires all the time 200-400 is the going price.
96 Outback - Starting Issues
lmdew replied to mattpa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you want to try a starter, I have good used one for $25 shipped. Lmdew@hotmail.com
Auto to manual tranny
lmdew replied to jeep5.9litre's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLots of info, just do the search. A few days of work on the older Subarus, once you go to OBDII you have more stuff to take care of.
98' Legacy- gas gauge not working
lmdew replied to paintypants's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe fuel sending units are easy to clean. A wiper and a board. After you have burned off a little fuel, pull the carpet up in the cargo area, just aft of the seats. You will see two covers, one on each side. Pull the covers and then the sending units/pump. Clean the contacts and make sure the wiper is in contact with the board. That should do it.
Front Windshield Defroster 98 Outback
lmdew replied to abeauch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook in the engine compartment at the firewall in the top center. There is a 1" or so hole. If the wire is not there, the windshield was replaced with a non-heated windshield. I just had mine replaced and didn't know it was a wiper heated windshield. The window guy said most folks never use it. Keep the windshield pigtail and then you have an extra 12V switched source in the engine compartment. Lights.....
help 97 Outback swapout 2.5 for 98 2.2
lmdew replied to mechdoug's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can pull the lines and pressure fitting from a 95 PS and put the right onto the 98. The 98 lines will work, but they are hanging way out from the engine manifold mounts. Nothing to bolt the two clamps to.
FSM Info need 97 Legacy 2.2
I have torque bind and the TCU has code 24 stored. I cleared it and it came right back. Cleaned all the plugs no help. The code is - shorted/open C-Duts S. I'm Looking for the correct pins/wire colors at the engine compartment trans plugs so I can test it with out pulling the transfer housing. Thanks for the Info! I pulled the rear half of the rear drive shaft, but don't like the idea of driving that way. Has anyone driven in that condition for any length of time? What were the results?
Torque bind problem fixed
lmdew replied to gyuunuuya's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you check the C-duty S from the trany harnes before you pulled it apart? I have the same problem on a 97 Legacy 2.2, code 24 - shorted/open C-DS. I'm Looking for the correct pins/wire colors at the engine compartment trans plugs so I can test it with out pulling the transfer housing. Thanks for the Info!
TCU Diagonstic Connector #5
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, saw that connector and the jumper. Thanks!
Searching the board, I found the procedure to pull the TCU codes from my 97 Legacy 2.2 auto trans (trans oil temp light flashing 16 times) telling me there is a code. The procedure indicates I need to connect the #5 diagonstic connector located under the dash. I've not been able to find it. The standard D-Check green single wire plug is there, but that's not what I need. Using the following: Gear Selector in D Turn on the Ign select 3,2,1 then press the gas half way. The light stays on steady. I also did not get the FWD indicator when I put the fuse in. I'd like to get the codes out of the TCU before I call it toast. Thanks
Separator plate, VC seal, seat cushion 99 Legacy Outback wagon
lmdew replied to SubaruForDan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can either pull the engine or the trans to get at the oil seperator plate. No the dealer would not have done this as it would add to the cost of the front engine work. If you pull the engine for the HG or clutch if its a standard trans, then yes a good shop would do it. You may want to try the WRX seats, lots of them at nasioc.com site. As for the HG if it isn't broke don't fix it. You may get past the inspection if you clean everything down real well, you could even stick a pie plate up there to grab the oil. Just make sure you do not run out of oil.
Where to find a plastic clutch alignment tool?
lmdew replied to hankosolder2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBoth Clutch Kits I purchased came with the alignment tool as part of the Kit.
Outer CV Joint Failure
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, flushed it all, I pull the upper radiator trany coolant hose, put another hose on the fitting and let it pump out the old stuff as I'm adding new fluid. It works great. This is after a drain and fill of course. 177K, on the car in otherwise good condition $600. I figured at that price I could replace just about anything. I'll do some more checking today, may just be the C DS.
I picked up a 97 2.2 Legacy Auto. The guy thought the trans was shot, but I found the passenger side outer CV joint cage in lots of parts. The boot was still good, but the shaft could turn inside the housing. I replaced the half shaft and its working. There is some torque bind. I flushed the fluid and will give it some time. I'm also going to see if the FWD fuse makes any difference. Has anyone ever seen a joint fail due to torque bind? Thanks
'98 OBW Limited - What's it worth?
lmdew replied to srponies's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust sold the same thing for $4500. The 2.2 did not come in the Outback other than the 95. I've sold 4 of these swaps and always put the fact out there so the new owner is not in for a shock the first them they get maintenance done.
1999 Legacy Speedo
lmdew replied to Slegacy96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a complete gauge cluster FS. Reasonable offer accepted. Lmdew@hotmail.com It has about 55K on it.
Who did the Dual Range Forster?
I know someone on the board put a dual range in a 98 Forster. Who was the man? I have some questions about the speedo input and wiring on that swap. Thanks,
timing belt tensioner???
lmdew replied to eventoday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpull the old style tensioner and mounting block off a old 2.2 89-95 and put it in yours. It bolts right up and then you don't have to worry about the new one failing.
Swapping a 1995 2.2L into a 1998 Legacy Outback
lmdew replied to BikeRack's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey drop right in and you can't get a better engine. CCR has a great product and are very good people to work with. I've done 4 of these swaps and I'm happy with the results. I grab the purge canister from a 90-95 and install it in the engine compartment, but you can also use the stock one. If you need the canister, just hit the local yard. It takes about a day to do the swap. Less time if every nut and bolt is not rusted tight.
