lmdew
    157
Everything posted by lmdew
  1. There is a 2 pin blue connector on the back of the Dash. I believe that is the speedo connection. I'd check to see if you have it on the gauge cluster and then use the wiring manual to find the best place to connect you VSS to it.
  2. If it blinks 16 times, you have a code in the Trans computer. You can search the USMB for the access steps to get the code. Most Transmission shops will pull the code for you for free, if you ask them to take a look at the trans.
  3. Fuel Temp sensor is on the Fuel Pump bracket, but it is not part of the fuel pump. It's about an 1" long and 3/8" dia.
  4. A little stored energy in the driveline. I put my parking brake on when I park my 2000 Impreza OBS.
  5. There are 2 small coolant lines that go to the throttle body. Check those. Your low idle could be due to a failed coolant temp sensor. On top of the block in the crossover manifold for the coolant. Passenger side under the intake on the back side.
  6. I'd first remove the intake tube and clean the throttle plate and intake. There is a adjustmet screw on the drivers side of the linkage. Make sure the cable has some free play. I'd recheck then.
  7. We bought an 06 Forester from a Subaru Mechanic which had a rattle. He said it was internal to the muffler and a common fault. I got a muffler out of the yard and it's been fine for the last 5 years. www.car-part.com is a good source. Get one from a location out of the rust belt!
  8. Friend had a 98 Legacy Outback sedan. She had a shop do a bunch of front end work, bearings, rotors... Turned out to be the rear disk brakes. I had them turned and installed new pads. I made sure the pins were free and greased. Vibration went away!
  9. Here you go. A new hood and you should be good. https://denver.craigslist.org/cto/d/arvada-1995-subaru-legacy/7469232186.html
  10. Not worth shipping. I found them on the Craigslist. Yes they did want proof of owernership. I had titles from cars I had parted years ago.
  11. Sold 3 CATs yesterday to a recycler for $125 each. They even picked them up. They wanted the Part Number off the CAT. There is a # under the heatsheild on a metal tab that comes off the seam. You have to cut the heatsheild back a bit and then wire brush or sand the tab to see the #.
  12. Sometimes the socket connectors do not have the contact force needed for a good conection. Bend them out a bit to increase the force.
  13. Who put the pump in the car? Did they bleed the air out of the system after the pump change? I'd get it up on jack stands or a lift. Drop the plastic lower engine cover if it's there. Start the car and turn the steering lock to lock while checking for leaks. Watch the fluid level.
  14. Muffler shop, to cut and weld in a section. If you want to keep the joint, see my post above.
  15. I may have the Mid and muffler for you. Shipped from 80919. I could cut off the flanges and as much pipe as you want to reduce shipping. Have a shop expand the pipes slip them on and bolt and clamp them up.
  16. I'd at least pull the timing belt covers off. I picked up a 2001 that sounded like a rod knock. It turned out to be the timing belt cogged Idler bearings were gone! I'm still driving that $400 car.
  17. http://opposedforces.com/parts/forester/us_s10/type_10/exhaust_system/exhaust/illustration_1/
