153
Everything posted by lmdew
It may be the bolts that hold the muffler pipe to the cat. There are two of these with the springs. Take a look. The yards can't sell cats, but they can sell mufflers. A wide range of years will work as there was little change. Say 90-96. I do have a cat back pipe from a 93 Legacy Wagon that is in great shape (CO Car). Let me know if you need it. Larry
I have not found any limits for the shaft to diff cage play. I have a 92 Legacy with the drivers side having a 1/16" of play between the cage and shaft. I've check lots of them in the yard to get an Idea of wear limits. I've seen very high mile Subaru's with almost no play and some with 1/2 the mileage <100K with large amounts of play. The Diff bearings wear is diferent from the wear of the cage to shaft. If the cage has limited play (check this with the shafts removed) then the cage support bearings are not the cause of the shaft play. I don't know if this helps, but I've not found limits for shaft play.
The engine harness should be the same, as long as the connectors are the same. I swapped out a 92-93 and had to change out the engine harness. The ECU and Harness also ties into the Dash Harness, which is different between the auto and manual. Both are a paint tu pull. The main harness from the ecu to engine also has all of the lights.... for the front of the car. The fender has to be pulled to get it out of the car. What problems are you having with the current harness? Later, Larry
You can do a search for this, several post have come up, but not its not hard and no alignment will be needed if you: 1) break the torque on the axle nut 2) remove the sway bar link from the side your pulling 3) pull the ball joint pinch bolt out of the bottom of the hub 4) drive out the spring pin from the inner hub 5) pry the lower A-arm down to pull out the ball joint out of the hub 6) pull the hub and axel out to pull the shaft Replace in the reverse order. Recommended to use a new spring pin and make sure the hole lines up. If its 180 out, you may get the pin in, but you will never get it out again.
Pull only one side at a time. Replace the seal and O-ring, lube the outside with light motor oil and carefully spin it in by HAND. The threads are very fine and can be cross threaded, Make sure the threads and bores are clean and free of any damage. Spin the assy in as you go so it does not cock in the trany. As pointed out mark a alignment point on the trany and housing.
They bolt to the intake manifold, so they are not truly inline. You would have to machine a adapter plate and hose fitting. You can see Pictures at. http://www.1stsubaruparts.com Loyale or Legacy, they have two different style IAC
I have a 92 FWD Auto Trans Legacy that was missing a differential dipstick. I picked up a yellow one from the yard and filled it to the full mark. It is leaking from the shaft seal a little. Today, I saw a black dipstick which was about 2.5" longer (about 11"). With it installed, the diff is 2.5" over filled. Will someone with a FWD 90-94 I think check, and let me know which is correct. Thanks Larry Yellow Plastic top Dipstick - straight shaft about 3/16" dia 7-8" long Black Top DipStick - bent shaft with mid support 1/8" dia about 10-11" long Thanks for the correct Identification!
Replace them if you can find good ones. I do have a good drivers door, but its red. Hey for $50 what do you want. You can have it painted and then install it. Its from a 96 Legacy wagon, you'd have to check the interchange to see if it would bolt right up. You pay shipping. Lmdew@hotmail.com By the time you pay the body shop to fix the dents or cut out the rust and weld it up, the replacement and paint will be less.
Rims
lmdew replied to freakus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I think that is the rim width. -
Rims
Yes, they will. They have the same 5 X 100 bolt pattern. -
Double checked Distributor/Bad Bushings
lmdew replied to lefty2053's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Are you sure you have a good vacuum source? Let me know if you need a Dis. I can pull them from the yard for $20. Colorado Springs. You might try hooking a vacuum pump to the dis and advancing it when its running. They are about $30 in the auto parts stores. Lmdew@hotmail.com -
94 loyale - idle up and down regularly???
lmdew replied to vanagonfan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Air control valve on the front of the SPFI. Pull the hose off and plug both ends with your thumbs. I bet it will idle rock solid. Later, Larry -
I have a 92 Legacy Sedan FWD Auto and the drivers side has excessive play in the stub shaft. I checked the bearing retainer for the differential housing and it was tight. The play is between the stub shaft an the differential housing. Anyone have the limits in the clearance between the parts? Does it require a differential rebuild to fix this? Thanks Larry
That's it. The full part number on the blue tag is: 26731AA200 Additional numbers on the tag Nippon 110 000 30460, in th silver box on the tag is 467-0424 4 lines on top 3 cyclinders between the upper and lower blocks 2 lines coming out the bottom engine side block. If you send me and email I can send a picture or two. Later, Larry Lmdew@hotmail.com
