157
Everything posted by lmdew
AC and Fan?
lmdew replied to David C's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Replace or Swap the relay for the fan. Its in the fuse box on the drivers side of the engine compartment. Check the grounds to make sure they are clean and tight. -
I had a Loyale that was doing the same thing. Found a wire melted up in the wire run behind the dash. Look at the back of the fuse box for signs of over heated wires. If you find them, trace them back to the source of the problem. The 6' wire was melted in several locations and in contact with other wire cores.
abs modulator
lmdew replied to mjm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I have a good used one $100 shipped. Lmdew@hotmail.com -
abs modulator
I have a good one, $100 shipped to you. Lmdew@hotmail.com Its easy to change and has good results. Used is not a problem. -
Look for any signs of oil in the coolant overflow tank. Any black stuff is a sure sign of HG failure. Take is for a long test drive if you can 50-100 miles and watch the coolant temp gauge. Most of them are rock steady just below the 1/2 mark. When its up to temp, and you've driven it hard, stop an look for air bubbles in the overflow tank. A few is OK anymore that that I'd walk away or get a great deal and drop a new 2.2 in from CCR.
I have a 92 Legacy 2.2 FWD Auto with a lot of play in the drivers side differential output shaft. The differential cage support bearing looks good and the side play of the differential cage is OK. I tried pulling the shaft to check it for wear, but even with my slide hammer it would not come out. I’m thinking the spring clip is bent up out of its grove. I’m looking for a replacement differential, what years models will bolt up? Thanks
Not tough, but time consuming. You have to deal with the ECU looking for the neutral switch, the cruise will need the clutch input, as well as the ignition circuit..... It can be done, but its not a plug and play. It depends a lot on if you want all of the safety inter locks to work or not. You will need the: Trans brake pedal box shifter rear trans cross member center counsel standard cover clutch master cyclinder and slave I'm sure there is more, If you have a car you can pull it from get everything thats conneted and then some and you will be OK
Easy job 30 minutes and you should have it off! 1) Disconnect the negative battery cable 2) Disconnect the positive cable from the starter 12mm nut I think 3) Pull the other starter wire from the starter terminal 4) Remove the bottom starter nut 15 or 17 mm. A 6" extension and socket work well. 5) Remove the top starter mount nut and bolt 6) Remove the Starter. Take it to the local auto parts or starter rebuild shop and have them test it. Less time to install it!
I had a 90 Loyale that blew the fuse to the Ignition and caused the warning lights to go out. I replaced the IAC, the purge and ERG control valves. It stopped blowing the fuse, but when the Kickdown relay was activated the volt gauge still dropped to 8V. It turned out to be a shorted dash wires. Several of them were melted and fused. Not Good. Look at the back of the fuse block and check the wires for the fuse that blew. Any signs of overheating should be followed. Many of the control items use the same common ground and or share the power source. It was a long long fix.
