176
Everything posted by lmdew
For the HG, check the overflow tank. Any oil residue is an indication of a leak. If you can run it hard for at least 30 minutes and then check for air bubbles in the overflow tank. Tires should match, the AWD does not like different sizes, they say within 1/4" rolling length of the tire. Standard Trans is better than the Auto. Auto should be serviced every 30K or so. $5500 is a little high, but reasonable if the car is in good condition.
O2 Sensor check?
lmdew replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If you have a Quality multimeter, you can back probe the O2 sensor and record the V as you drive. If you watch it you should see regular crossovers and voltage. Due a search for V values for rich and lean. I don't have them off the top of my head. -
There are two vents on top of the trans 1/4 rubber lines. I doubt they would completely block the fluid from going in. Are you using a transmission funnel? Many of them have a shutoff valve at the bottom before the hose. If you think its the vent, pull the drain plug, does flluid go in and out of the trans now?
Pull the center counsel up, you will find two screws at the front Lift the cneter counsel lid and remove the 4 scress I think that it, but there may be a couple on the back side down by the floor Now you have full access to the brake handle. If you don't need the cables, cut them and unbolt the handle. You've got it out. Do the same on your car (don't cut the cables :>) adjust the cables per the book. Easy job 30 min and your done.
slips in reverse
lmdew replied to ptrent's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
My son's 93 Turbo wagon does the same thing. I have not found a fix yet. The fluid change/flush had no effect. It works when cold, so I do not think its the clutch pack. -
Pull the plug at the top of the engine just behind the IAC and you can see the flex plate and 4 bolts. You could also grab the fwd drive shafts and see if you get a lot of movement at the output shaft of the fwd diff. I could be a diff problem, but sounds like a flex plate. I've tossed a few of these already. Check with someone that has done the auto manual swap.
starting problem
lmdew replied to serac's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Contacts in the starter are getting bad. Moisture makes the problem surface in the AM. New starter or have the contacts in the solenoid replaced by any starter shop. If you want a good used starter to put in, send me $20 to cover the shipping and I'll send one out. Larry -
ERG Valve is on the 95. The biggest reason to install a 95 is its the last year of a non-interference engine. If you need a good one, go to www.ccrengines.com. They will even build one with cams to regain the minimal power difference. The Impreza 2.2 will also work, but check the flex plates. The Impreza is about 1/2" dia smaller. Don't ask how I know! I've done two of these swaps and I'm happy with the results. If you get the power steering lines and the fitting off the pump, you can change the lines over as well. I also grab the purge canister and bracket that is bolted to the right front frame rail. Then you only have one vaccum line to plug.
You need to bleed the system. Jack the front of the car as high as possible! Remove the upper hose and slowly fill the system. When the upper hose will take no more collant, connect it to the radiator Continue to fill the system through the radiator cap with the bleed plug removed. Burp the system, squeeze the upper and lower hose. When you get no more bubbles, start the car and let warm up Collant should start to come out of the radiator cap, install the cap and let it get to normal temp. Shut the car down and let it cool. Collant should be pulled out of the overflow bottle and into the radiator. Complete the warm-up & cool down cycle a couple of times. Take the car off jacks and test drive. Subarus get air locked and coolant does not flow.
