157
Everything posted by lmdew
The trans shaft is inside a extension housing, think of a shaft inside a pipe. The T-bearing is outside the pipe and slides on it as the fork moves fwd and aft. The T-bearing is like a 2" long pipe with a bearing attached to the end. The pipe does not rotate, but the bearing pressure surface does. Hope that helps. If you need more info, just stop at your local auto parts store and ask them to see a clutch Kit. It should have all the parts.
Sounds like the CV joints. You don't do high speed 90 degree turns, so you don't get the vibration. Take a good look at the joint for boot failure. Hold the drive shaft and move the wheel. There should be little to no play in the joint. Try backing up in tight circles and listen for clicking sounds. A sure sign of joint failure! If you need replacements, I have used ones for $10+shipping. I also have a spare rack if you need it. Later, Larry Lmdew@hotmail.com
tires?
lmdew replied to jstriker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
should fit no problem. We have the stock WRX wheels and tires on my son's 92 Legacy wagon. They are 205/55/16 -
The sensor is right above the crank pulley, mounted on the front of the block. One 10mm bolt and the electrical connector is all that needs to come off. You may want to pull the alternator to give you better access. Easy swap. Check 1stsubaruparts.com for good service and price. If you have a good self service yard, you may just pull one.
where to get the ECU rebuilt
lmdew replied to Petersubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There is one in my local yard from an 89. I can send it for $45 shipped. Lmdew@hotmail.com -
Starter???
lmdew replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I have a good starter for your 2.2 both auto and manual. $35 shipped to you. Lmdew@hotmail.com -
Easy to change and I have a good one if you need it. Look up under the glove box and you will see the fan. 3 nuts and a connector hold it in. I guess you have a lot of use on your fan. I had one, that stopped working as the brushes wore out. It checked good with the multimeter, but was shot. Pull it and hook 12 V to the connectors. That will let you see the fan work. It is easy to drop the glove box which gives you better access. Just flex in the sides and pull the hinge screws. Later, Larry If you need the fan send me an email. Lmdew@hotmail.com
You might try dropping the exhaust pipe of the back of the CAT's and see if it makes a difference. If the exhaust is still very quite, you may have a plugged CAT. I would think you would get a code, but who knows. It's just two bolts, so it's worth a try. If there is no change, drop the CATS, it will be straight pipe now an should rev like crazy.
You could check the pressure out of the pump by tapping into the pressure line with a gauge. Or you can pull the return line and see if fluid is being pumped back to the PS unit. If you find out you need a pump, I have a good one from a 96 Legacy wagon 2.2 motor. I believe they are the same. $30+shipping. I also have a good rack, but I don't know about the interchange. Lmdew@hotmail.com
With new rotors and pads, there should be very little if any noise! I'd drive is some and see if you can identify specifically where its coming from and when it happens. How do the brakes work? If they are working fine, they may have just bent a part a little and it is hitting sometime. Have them check it again after a few more miles.
It's and easy job, two mount bolts and the wires to the starter. I'd check to make sure your cable were clean and tight. 60K is low miles for the starter to go. A used starter will be the cheapest, but any good rebuild will get you going. You could also pull the starter and have it checked by a starter rebuild place. Later, Larry
Pull the bottom trim, if you haven't already. Look for a black two wire plug. These wires go to the coil to release the key. Check for a complet path. Then try putting 12V and a ground to the plug. This should release the Key. If that fails, look at the lock assy. You will see a small rod which you can push back. If that works, leave the black plug disconnected and you are done. Just make sure you put it in park, as you will now be able to remove the key in any gear.
Head Gasket
lmdew replied to hacket69's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Fill and bleed the system and get it back to the shop that did the work. It shouldn't be doing that. Check to see if an easy fix, but still let the shop know so it doesn't happen to the next person.
