lmdew
    153
Everything posted by lmdew
  1. The passenger side has the pump and sending unit. The drivers side has a sending unit and a fuel pickup to transfer the fuel over the hump in the tank. Both sides are used for proper fuel gauge readings. If you need the units, I have both from a spare car we parted for my son's auto to manual trans swap. Lmdew@hotmail.com
  2. If there is no signs of leaks, are you changing the Oil Pump Oring when doing the timing belt? I usually do the cam and crank seal along with a water pump every other timing belt, but I've seen some talk on changing the oil pump Oring also. Your thoughts?
  3. This is common, first lube it with liquid wrench. After it sets for awhile, try using a pliers to put pressure on the sides of the insert. This might work, but if they are corroded, you will most likely end up pulling the insert out. You can try driving it out from the back if you have access, otherwise just pry on both sides of the bolt. You may be able to glue them back in, otherwise its the dealer or junk yard for a replacement. Good Luck
  4. This happened to my son's 93 Legacy, 2.2. It was a combination of the cooling fans going out and a HG leak. Being a new driver, he didn't notice the fans were not working properly. This caused a minor overheat, resulting in a head gasket leak. It was minnor and did not cause problems all of the time and the overflow bottle was never low as the coolant was not being pulled back in to the engine as it cooled. Have a shop check the coolant for exhaust gases. That will confirm the HG leak. Good Luck. COS
  5. Make sure all of the cables and ground point are clean and free of corrosion. Poor contact can cause these conditions. Good Luck
  6. I'd ask to make sure it didn't max out the temp gauge. You may have a headgasket problem if they drove it with the pump problem for any length of time. Just a thought.
  7. To change all of the fluid, pull one of the cooler lines from the radiator and run it to a bucket. Allow about a quart to pump out, stop the car and refil the trans. Keep on doing this until you've flushed the system. Works Great.
  8. I have several used if you want to try one. $15+10 shipping. Lmdew@hotmail.com
  9. Anyone have the ation sheet for the auto door lock module? I picked it and a security system up and would like to the auto door lock unit. Thanks
  10. I got the plugs changed but what a pain. There is only about 1.5" between the engine and the frame, so little you have to put the tools in one at a time (socket, extension, ratchet). The only way to make this job less of a pain would be to raise the engine. Anyone have a solution? I know you only have to do it every 60K or so, but the designers weren't thinking of the Mechanic.
  11. my 93 Caravan has been making that noise for the last 90K miles in turns. If it isn't broke, don't fix it. Just a thought
  12. If you go to tirerack.com and check both cars you should be able to tell. They have both stock and other size wheels available. Good Luck
  13. There's a 96 Legacy Wagon, I don't know if it has the same radiator, but if it does, its in good shape and the yard gets $40 for them. Plus shipping, its a deal. Lmdew@hotmail.com
  14. I change mine every other timingbelt change. Of course I check it carefully along with all the other parts at every change.
  15. 0.45 to 0.49 is considered optimum for most cars. If you can drive the car with a recording multimeter hooked up you can then get the average. The Fluke 87 meter will do this, they run 130 or so used on ebay. Not cheap, but its a great tool.
  16. I have a good Muffler and pipe you can have for $20 + shipping charges. I'm in Colorado. Its off a 92 Legacy Wagon, should bolt right up. Good condition Lmdew@hotmail.com
  17. If you want to sell the car let me know what you need for it. I'm looking for a standard OBW 97-99 with a bad engine. Lmdew@hotmail.com
  18. I'm in the springs, I can fix it or give you a good deal on a used pump. My son and I just did a engine and trany swap on a 93 Legacy into a 94 Legacy and we have a spare pump. Give me a call 268-9750 Larry
  19. Install a coolant flush tee in the heater hose and then fill with the cap off. This speeds the filling process and lets the air out. Finish up the fill as the manual recommends.
  20. Are you talking about the tool tray on top of the spare? If so, I have one from a 93 Legacy Wagon that will fit $10+shipping. Larry Lmdew@hotmail.com
  21. Anyone found a larger Quality Oil Filter for the 2.5. The OEM filter is so limited on filter material area.
  22. I've got a 98 2.5 with 12K I purchased for a 97 I thought was making metal. After some assistance from CCR, it was determined the engine was OK. By that time I had the 98 on the way. I verified the mileage with carfax, but I don't have the vin any more. I bought it for $2500, but will let it go for $2100 plus shipping. Email me if you want it. Lmdew@hotmail.com
  23. If you find you need the sending unit, I have one out of a 92 Legacy wagon you can have for 20+shipping. Lmdew@hotmail.com
