157
Everything posted by lmdew
The sensor is on the drivers side, just behind the manifold where the gas cables connect. Its straight down, a single wire goes to the sensor which is about an 1" dia. A single 12mm bolt holds it on. Do NOT over torque the new one. You can take a resistance reading, but I've not had much luck checking them that way. Good Luck.
Look for oil and or air bubbles coming to the top of your coolant recovery tank when its hot. Make sure the coolant is drawn back into the radiator when the engine is cool. If it doesn't do this is its a HG. Make sure you have all of the air out of the collant system. Very slow fill when you add coolant with the bleed screw out. I also like to add a coolant flush Tee to my heater line to let the air excape there. Good Luck
No, a stiff 1.5" blade putty knife will assist you in getting the pop in fastners. The door handle trim is the hardest, about the center of the trim top and bottom there is a tab that clipd over a pin. You need to gently push them up to release the trim. If you have problems and don't mind driving to the north side of the Springs, I can get you back up in no time. Larry
I was thinking about doing the same swap, but after all of your issues I think I'll stay with the 2.5 Good Luck! Sounds like the relay that puts power to the ign side of the system might be stuck closed, always hot. You might pull it and put a meter across the contacts. It should be under the dash, I believe.
Coolant Issue
lmdew replied to JBRIII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Check the exhaust for coolant smell. If you have it there, its the head gasket. The waterpump may be leaking down on the exhaust. Look along the driver's side on the oil pan flange. -
The passenger side has the pump and sending unit. The drivers side has a sending unit and a fuel pickup to transfer the fuel over the hump in the tank. Both sides are used for proper fuel gauge readings. If you need the units, I have both from a spare car we parted for my son's auto to manual trans swap. Lmdew@hotmail.com
This is common, first lube it with liquid wrench. After it sets for awhile, try using a pliers to put pressure on the sides of the insert. This might work, but if they are corroded, you will most likely end up pulling the insert out. You can try driving it out from the back if you have access, otherwise just pry on both sides of the bolt. You may be able to glue them back in, otherwise its the dealer or junk yard for a replacement. Good Luck
This happened to my son's 93 Legacy, 2.2. It was a combination of the cooling fans going out and a HG leak. Being a new driver, he didn't notice the fans were not working properly. This caused a minor overheat, resulting in a head gasket leak. It was minnor and did not cause problems all of the time and the overflow bottle was never low as the coolant was not being pulled back in to the engine as it cooled. Have a shop check the coolant for exhaust gases. That will confirm the HG leak. Good Luck. COS
