lmdew
    153
Everything posted by lmdew
  1. Best to pull it and see what's there. Subaru's are like legos plug and play. There are some differences! Fly wheel dia for one.
  2. The Forester trailing arm body to arm mount is a little longer. If you are in the rust belt, use lots of Kroil and a breaker bar to work the 3 bolts out. Took a Milwaukee impact to a friends in WI and we broke the welds on the captive nut inside the frame. Solved that one by drilling an access hole into the frame from inside the car so we could put a socket on the nut.
  3. I had the new CCR do two engine rebuilds for me for cars I was fixing and selling. I was happy with both and never had any questions back from the new owners.
  4. Could be that 5 gallon bucket of Subaru nuts and bolts in the front seat. You got away before I could load it. Glad you made it.
  5. Rear Seals are usually NOT the leak source. The seperator plate on the back of the engine needs to be resealed. If it's the plastic one, Subaru has a replacement metal plate. Early ones were aluminum. Don't touch the rear seal unless it damaged or you can confirm it's the source of the leak. Most folks have more issues after replacing the rear seal. Having the sleave kit is nice. No way to tell if you need it until the engine/trans is pulled. The belt should be fine, another 20K to 60K left on it. Did you change all of the idler pulleys on the T Belt? if not, I'd to them now while the engine is out. Valve cover gaskets. Oil Pump reseal and rear cover plate screws torqued properly.
  6. Always happy to help and visit with USMB Members. Parts are mostly 95-99 range Legacy and Impreza. Of course you know Subaru's are like Lego's many parts interchange. Thanks for stopping in!
  7. Check to see if the large 1" dia hose going from the Air Box to the Idle Air Control Valve is connected. It usually comes off when the air filter is changed or top of the air box is removed. Use a Subaru MAF! NGK copper core plugs are best. How did the plugs look that were removed?
  8. I've been very happy with the 95 2.2 swaps I've done. www.car-part.com still shows some low mile engines. 96-98 2.2 will work but require a single port y pipe. Watch for EGR configuration for plug and play the 95 2.2 with matching ERG is great.
  9. If you are in Colorado Springs for a few day you might be able to get in to see Casey at http://resolve-therapeutics.com/. She does a great job on my back after long flights.
  10. Should have had another cup of coffee. Bus crossed a double, double yellow line turning into a gas station. Said he never saw me. I'm here. Any Day you can get out of bed, have a hot coffee and shower is a Great Day. If you make it to the end of the day and have an IPA it's even better!
  11. Good PT and yoga have helped me! 2014 head on motorcycle to school bus accident, at 60 mph made me a slow moving vehicle. But hey, I have all body parts and still get around.
  12. Hope all goes well. You can pull the lid apart and remove the struts from the piviot point. As noted, there is nothing under the counsel that would stop them from moving. Is something in the hinge?
  13. If you get a small pin, push pin works well you can put it in the hole and move it. It's a little ball and socket.
  14. Loadpro if you are reading voltage your meter can lie to you unless the circuit has a load. Loadpro makes it easy to check the wiring, Opens, Shorts and High resistance. https://www.aeswave.com/LOADpro-Dynamic-Test-Lead-p8955.html
  15. Do you have a good Subaru/Transmission shop near by? Might be worth having them take a look. At least you could get an idea of what's up. A friend had a 2013 Legacy that was giving him some issues. Shop said a Speed Sensor. I found a good PDF and he went to the yard and pulled the sensor. Swapped it out and all good so far.
  16. I've changed and pulled them from several 96-99 Legacy Outbacks. Rust free CO, easy as can be. I have not done one on a Forester.
  17. They are there for a reason. I'd keep them. You never know when someone pulls out in front of you.
  18. Auto? spoob lock can be manually released. Manual, have someone rock the car while you try shifting it.
