lmdew
    153
Everything posted by lmdew
  1. If you want me to send you pics of what I have let me know. Lmdew2@gmail.com
  2. I think you can see the shift selector from the passenger side engine compartment. Disconnect it and move it by hand. Make sure you have the car blocked. Jack it if needed and put on the rain suit.
  3. I've used Gray RTV, a light bead at the 90 Degree before the o-ring is put on. When you install the cap the RTV will be pushed out between the engine and the cap.
  4. I'm walking around Kauai and see the county has several Crosstrek Hybrid plugged in at the city hall. Anyone have one? GD are they worth a lick?
  5. I'm walking around Kauai and see the county has several Crosstrek Hybrid plugged in at the city hall. Anyone have one? GD are they worth a lick?
  6. 2006 5-Speed Subaru Baja -- RARE - $4,800 2006 160K, - CO https://boulder.craigslist.org/cto/d/hygiene-speed-subaru-baja-rare/7315449537.html
  7. Your meter will lie to you, unless you are checking the circuit under LOAD! Check out LOADpro. A great addition to your toolbox. https://www.youtube.com/watch?v=AYiY1c_b06w
  8. I like the single disk units even more. The multi disk changers are more to go wrong. I have several and the under seat base speaker.
  9. Got that as well. There is a metal bushing it goes through, washer end goes up against the engine bracket.
  10. Make sure you burp the system when you fill it! Subaru engines like to lock in air bubbles.
  11. Plastic tank to aluminum radiator core gaskets often leak a little. The vent plug has a rubber gasket on it, it's all that needed. Don't over tighten it!
  12. Might have a Subaru original for you, good or to have rebuilt. I'd need a picture of the top plug. I'm in Colorado Springs. USPS Flat rate $18. Larry
