153
Everything posted by lmdew
Power steering belt rubbed a hole in the upper radiator hose a couple of weeks ago. A quick fix. This thing was hit in the front as some point. I pulled the radiator support out a bit and it's been fine. Today going down the freeway, it seemed as if the engine cutout completely a few times. It always came back to life in a second. No codes logged. The temp went up a little but other than that nothing. I checked under the hood when I got home and everything seemed OK.
Hard to say, once someone cut into the wires. You'd need an O-scope to read out the cam sensor as it outputs a signal. They hardwired the cam sensor into the harness? You can check the Timing Belt by pulling both side covers and the crank sensor and looking down the hole to make sure the crank mark lines up.
I picked up an 05 Impreza, low mileage 60K. The Speedo does not work and it looks like the milage readout may have burnt out. I'm thinking a new gauge cluster. - The Timing belt has not been replaced, it's low mileage but old. I think it the idler bearings and seals should be changed. I'm also a fan if it's not broken don't fix it! Your thoughts? - Auto trans had a bit of torque bind, by feel. Not flashing trans temp light on start. The car did sit for years, so I hope the clutches were just drided out and it will free up with some mileage and a flush/TransX treatment. What do you think?
Lost !!!!!
lmdew replied to ocei77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I'd ask him to hook up his MAXISYS scanner and check to see what is happening. -
The trans chart I have did not find the TZ1A2ZJEAA, what did it come out of? Quick google search found this: 31000AD830 Genuine Subaru Trans AY/TZ1A2ZJEAA - Subaru … This part fits 1999-2001 Subaru Impreza, 1999 Subaru Legacy, 1999 Subaru Outback. Affordable, reliable and built to last, Subaru part # 31000AD830 Trans AY/TZ1A2ZJEAA stands out as the smart option. SubaruPartsDeal.com
I have not been into the 2005 Forester doors, but I could hit the yard and pull one open. Since it's in both directions, it sounds like the window regulator hardware. A good visual inspection will most likely tell you much. Let me know if you want me to open one up at the yard. You-Tube has a few replacement videos. Amazon has the complete part $60 Email sent with links.
Movie looks like the cable is correct. Not much latch info as the hood loop has to press the hook of the latch down to set the hood latch. Was it in an accident? You can take a screwdriver shaft and press down the latch to make sure it springs over center and locks. If that works, something is out of alignment.
