157
Everything posted by lmdew
Yes the fuel pump is only powered for a short time when you first turn the key on. Once the engine is running it's always powered. Sometime your meter may lie to you. If you have no load on the circuit you can read voltage but still not have what you need. You Tube search Load Pro. You might want to try the relay under the dash. If you can back probe the connector and leave it hooked to the pump that would also give you a better voltage reading. Check the circuit under load! When this happens you could also pour a little gas in the intake. If it fires you have confirmed it's a fuel issue. Gas water Free?
I have a bunch of fuel injector rails - Red injecotors, late 90's. Today I pulled 8 for another USMB member. The rails and Injectors were removed from the intake. I removed the Injector cap screws. I tried to push them out. They were stuck. I took a soft wood board, put it on the Injector and clamp against the rail and pulled them together. The Injectors popped right out. The softwood protected the tip of the injector. Nice.
You can hook up a multimeter to the connector. It's either OL - Open or 0.0 - Closed for ohms. Yes it does input to the ECU, slight impact on idle RPM. The two connectors are right on the back of the engine as they come up from the trans. Little 2 pin connector. Gray and Brown if my memory is correct. One for Reverse and the other Neutral.
Hope you had a Great Christmas in this strange 2020. Stay Healthy and Safe as we move into 2021! Happy Boxing Day.
- 1 reply
- 5
