Everything posted by lmdew
99 Legacy 2.2 dies at times, no Codes set?
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks. Cleaned the Cam Sensor connector and plug as it will not come out without pulling the valve cover. Swapped a Crank sensor. Newer engine, not the old airbox MAF. Random dies from what she has told me. Larry
1997 2.5 Power Steering fails, belt loose not broken
lmdew replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo it right the first time, is always what I tell Mechanics in class! Sad.
I help a friend get a 99 Legacy a couple of years ago. Lately it started to die at random times. It starts back up after a bit. No Codes set? Ideas? I hate just to change parts, but I do have spare sensors. I'm thinking start with Cam and Crank Sensor. I would think if the sensor was out it would have a code set. Or change out the MAF? Thanks, Larry
lmdew replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can lock up the flex plate - Auto Trans or Flywheel - Manual Trans and torque the bolt. The other option is to use a quality strap wrench on the balancer to keep the engine from turning. As GD said 150 ft lbs. I use to take them to 125 ft lbs.
It's Free but is it any good? FREE OIL UPDATED 2-21 to 3-27
lmdew replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, I called today. Another Hour on wait. Sent a reply email, asking for response by Tue. or I'm reporting it to Credit Card. I try to work with the stores first.
1995 Legacy wagon -- name that part...?
lmdew replied to bendecker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHead to the Junk yard - selfserve and poke around.
lmdew replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStill waiting for PB to refund my double charge on my credit card. Hope others have better experiences with them if they try the deal.
2000 Legacy Difficulty Starting - Fuel Pump?
lmdew replied to dirty_mech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour pictures show you in the circuit when measuring voltage. Never a good idea to be touching the pins with skin/fingers. Check out Load Pro on youtube. Great tool, to add to your meter.
lmdew replied to dirty_mech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck out LoadPro on youtube.
lmdew replied to dirty_mech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFuel Pump Relay. Check all battery and ground connections.
2002 forester transmission compatibility
lmdew replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs long as the Rear diff matches the Trans you are good.
fog lights not working
lmdew replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMake sure you are not on Highbeam!
93 legacy tailgate light on when it is closed and off when open
lmdew replied to Kharl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPull the rear plastic inner panel off. You wll see the latch in the center. There are a couple of wires there. The wiring from the FSM is good. You might also want to talk to the fellow that did the work and see how he replaced the rear hatch.
lmdew replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPepboys not on my list anymore. - They No longer carry parts in CO, nothing but a tire and MX place - Double charged my credit card for the oil - Could not complete the rebate form with the online order receipt - Spent over an hour waiting for customer service to pick up the call - BBB has numerous complaints on their Rebate program That being said, they are processing the refunds for both charges. You get what you pay for. Almost Free oil was not worth it.
rubbery burning smell
lmdew replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLove CO, none of that red stuff out here!
headlights dim at higher rpm before gear shift
lmdew replied to Richardb1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.car-part.com a good search engine.
lmdew replied to Richardb1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet a Subaru Rebuilt Alt!
Spark plugs? I need help.
lmdew replied to Baka.sti's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1+ on GD's shop. I told Friends in Bellingham, WA well north of Seattle to head down!
lmdew replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGot my 2! Thanks for the link.
98 Legacy Outback cold start diagnoses... Fuel pump?
lmdew replied to GorgeSuby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd start with the relay. Easy to swap, used ones OK. I've had the same problem more than once.
Ac condenser as a trans cooler?
lmdew replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou'd spend almost as much in fluid hose to get to the passenger side a you would for an aftermmarket trans cooler.
lmdew replied to GorgeSuby's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes the fuel pump is only powered for a short time when you first turn the key on. Once the engine is running it's always powered. Sometime your meter may lie to you. If you have no load on the circuit you can read voltage but still not have what you need. You Tube search Load Pro. You might want to try the relay under the dash. If you can back probe the connector and leave it hooked to the pump that would also give you a better voltage reading. Check the circuit under load! When this happens you could also pour a little gas in the intake. If it fires you have confirmed it's a fuel issue. Gas water Free?
Baja turbo power steering pump
lmdew replied to gurucrunch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've put clamps on the end of the hose, to stop the air from getting sucked in.
Instrument cluster problems
lmdew replied to Nvautomaster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDetails on your Subaru would help.
