157
Everything posted by lmdew
You can repin the ABS connector, remove your old connector and then remove the junk yard one and slip the pins into your original connector. The ball joint, just get a flashlight an look through the hole. You should see a clear path for the bolt to go through. I have never driven a ball joint in to far, I don't know it possible. I don't know what you have, I always had Subaru ball joints. Yes you could drive it without the ABS connected. You would have normal brakes, without any ABS.
Disconnect your neg terminal. Remove the two small wires from the ALT top 10mm nut. Hook up you battery and see if you still have the draw. Was it an aftermarket Alt? Are you getting the click from the Starter? Good wack with a block of wood sometimes gets the starter going. Could also try jumping the starter terminals.
CLUTCH ISSUES
lmdew replied to Wilco88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Bleed it first and also check the condition of the hose. -
Friend in Bellingham WA needs Subaru Maintenance. She was given a $5000 price estimate for the HG and axles repairs on her 2007 Legacy. It has 180K. She's wanting to know if it's worth it. I told her if it's been taken care of and with normal maintenance she should hit 250K. Lot's of unknown's from CO and having not seen the car. Her brother is in Portland, OR so GD shop is my pick. Larry
Search the form for burping the coolant system. Subaru engine like to trap air in the coolant system if not filled properly. It can lead to overheating. Overheating is not good and can contribute/cause HG leaks. Make sure you have a Subaru Thermostat and not an aftermarket one. Properly fill the coolant system and burp out all air. Drive it and watch the overflow for air and coolant being pushed out of the system. When the engine cools, the overflow coolant should be drawn back into the radiator. Check the radiator fluid level in the radiator when engine is cold.
