157
Everything posted by lmdew
Seat of the pants. Just drive it. Try tight slow circles in both directions, checking for torque bind. Make sure it shifts through the gears as it should. No AT Temp light flashing.
Cleaner the better. It's a bunch of work to change the trans. I'd rather replace 2 engines than an Auto trans. Heavy as can be. That does not mean with a good fluid flush once it's running it may be fine. Once you confirm it's working, drain the fluid. Fill, pull the upper radiator ATF line and run another hose into a gallon jug. Start the engine, watch all the old dark nasty fluid be pumped out. 3/4 full, shut off the engine, fill the trans with new fluid and repeat. It usually takes about 3 gallons to get all the old nasty fluid out. Hook up the radiator ATF line. Service to the proper level, take it for a long drive and recheck the fluid level when it's hot. Service as required. You are Done!
Junk yard hints. Look for cars that have been hit hard - in areas you don't care about. At least you know it was on the road. Look at the overall condition of the car, if it's in good condition you know the owner cared about it. Clean fluids are a +
Save on KYB Shocks & Struts at RockAuto
lmdew replied to RockAuto's topic in Products for your Subaru
RA does not ship to CO. Something about taxes. Crazy! -
So you are most likely seeing a coolant leak. To replace this, the Intake has to come off. I'd pull the hose, check the pipe, hose and clamp. You may be able to clean up the pipe and make sure the hose and clamp are good. Replace as necessary to fix the leak. The small hose going to the throttle body also sometimes leaks and will pool on top of the engine.
