153
Everything posted by lmdew
I've been using the Motive Products bleeder for years. It works great. Fill the bleeder with fluid. Hook it to your master cylinder and pump it up to about 8 psi. Hook a catch bottle to the bleeder and open the bleeder. Keep the bottle high. Watch for clean bubble free fluid coming out of the caliper. Close the bleeder. Move on to the next wheel.
I've tried several different programs from the web. None of them put the system in the program mode. This Forester does have the Security system on it. Here's the one that seems to be the correct sequence but again, the car is not going into the program mode, indicated by the beep. Sit in driver's seat and unlock all doors. Open and close the driver's doorTurn the ignition key from LOCK to ON position 10 times within 15 seconds. Be sure to stop at both lock and on. The horn will HONK once to indicate transmitter programming mode is activated. Leave key in LOCK position and don't remove it from ignition.You now have 45 seconds to complete the programming as below.Open and close driver's door again.Push either lock or unlock button on the remote you want to program. The horn will honk 2 times when successful.To continue and program other remotes at the same time: open and close the driver's door and push lock or unlock on the remote. The driver's door must be opened and closed between each remote you want to program.Done programming? remove the key from the ignition and the horn will honk 3 times. Thanks, Larry
They all pretty much interchange. Some of the Seatbelt latches are different so you may have to swap the catch over from the old seat. You may have the wiring in your car for the heated seats. If not, the stock wiring runs all the way over to the passenger side, down the door and back to the middle. Forester seats sit about 1 1/2" higher. Most yards are NOT selling seats with airbags in them. So if you want a newer seat, cut all of the airbag electrical harness and labels off before you check out.
Rust Problem
lmdew replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
POR 15 products are great! https://www.por15.com/POR-15-Top-Coat-DTM-Paint -
Yep, and please teach the young ones to check oil ever gas fill up! Take a good look under the hood check the fluids and check tire pressure as well. On Subaru watch that temp gauge, they run at the same spot all the time. If temp is climbing you have a problem. Check it! For fun, I've fixed and sold many Subaru, keeping them on the road. I always off to teach/show the new the owner above. If a Teen is interested in learning to change oil and do basic maintenance they are always welcome in my garage. Larry
