157
Everything posted by lmdew
Get a Motive brake Bleeder. They work Great! https://www.amazon.com/Motive-Products-European-Bleeder-Pressure/dp/B0002KM5L0/ref=asc_df_B0002KM5L0/?tag=hyprod-20&linkCode=df0&hvadid=198100799464&hvpos=1o1&hvnetw=g&hvrand=902790476625103202&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1014471&hvtargid=aud-801381245258:pla-380942840295&psc=1
96 obw exhaust
lmdew replied to Cfoust's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The rest of the system CAT back are the same. Look at your O2 Sensor placement. They do vary year to year. -
96 obw exhaust
If you want to measure lengths and send pictures I'll see what I have. 80919 is my zip for shipping. -
I'd fist check and see if the cable is on the lever attached inside the car. If so, have someone push down on the hood when you pull the lever and then pull up the hood. If the cable ball end is not attached to the lever under the dash, you could just pull it with a vice grips. If neither of those work you will have to get into the grill area to pull on the cable or unbolt the latch 12mm bolts.
96 obw exhaust
I most likely have a complete exhaust for it in Colorado. Shipping is not cheap but neither are cats. What's up with yours that you are changing it? Did it come from the rust belt? -
96 obw exhaust
You most likely have a single port exhaust on the 96 2.2. You can find the aftermarket Y-Pipes and they are pretty good. Cats you can't get from the yards anymore, but can find them used. I have a few in Colorado Springs, CO. Mid and rear exhaust pipes can be swapped out. Just need to match the length. -
He had it checked by the local Subaru Dealer and they said it needs a short block? Well loved Impreza for sale, needs new short block (timing belt went out). Has brand new Blizzaks (less than 3 weeks old), brakes / rotors done 2 months ago. Car is in great shape except for the necessary engine swap. Great project for someone with the know how. https://cosprings.craigslist.org/cto/d/colorado-springs-06-subaru-impreza/7053573916.html I'd think bent valves but a block? I don't know the newer ones like the old 90's so I thought I'd ask. Thanks
