153
Everything posted by lmdew
Make sure you check the coolant in the radiator, when it's cold. Many times the coolant will not pull back into the radiator so the overflow bottle seems full but the coolant system is low. Good visual of all hose connections, recommended. Check to make sure all the fans are working. Is it an original Subaru thermostat? Don't use and aftermarket.
Drain fuel
lmdew replied to Foilmonkey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If you cut the car side of the connector from the junk yard, you can hook the + and - to a battery after you have plugged in the junk yard connector under the seat or in the cargo area. -
Yes a steep hill will work as well, if you don't have a floor jack. A couple I've had to run down the road a bit. No heat coming out the vents, temp would go up higher than usual. but then temp would drop and heat out the vents. Air block in the engine can be tough sometimes. Most go well and are easy fill and burp. Heat comes out, temp stays solid 1/2 way up.
I jack it as high as my floor jack will go. Yes pull the upper radiator hose and slowly fill the block. Once the block is full, put the hose back on and fill the overflow bottle and radiator about 1/2 way. Start it up with the heat on full. Once coolant starts to circulate squeeze the upper radiator hose to burp it. Keep on doing that until you have no more air bubbles in the overflow. I've had one or two that were very hard to bleed. I finally got them. Good Luck.
If you hit the yard and drop a headliner on an Outback you will be able to see all of the frame attaching hardware. The rack is mostly supported from the brackets inside. I hauled a 20 foot beam 6x10" over 200 miles tied to a 98 Outback roof rack. No problems. Stacks of plywood, no problem. Just have to tie it on well.
Look at your new pump and double check all the bolts. It's sealed on with RTV or the Subaru sealant and you have to pop it off. Look at the bottom of the pump. The 2 round extensions on the casting extended below the block. You can take a large pry bar or wood board and put it between those and the oil pan and pop the pump forward. Again check all the bolts first! Make sure you check and lock tight the oil pump rear cover screws if you are reusing the pump. Change the seal, Subaru recommended and get the oring seal. The one between the block and pump. I use Gray RTV to seal the pump on. Subaru does have a specific sealant to use.
