153
Everything posted by lmdew
It's just a matching air fitting for the bleeder and a matching pipe thread fitting on the inside.
- 5 replies
- power bleeder
- brakes
(and 2 more)
Tagged with:
If you have the 2 part rear drive shaft, yes you could remove the rear half and drive in FWD. The drive shaft FWD yoke into the trans keeps the fluid in, so it has to stay. If you can get a lift for the repair it's much easier. The most time is spent cleaning the gasket surfaces. The wire is very short so when you pull the tail shaft back, take it easy. I'd leave a bolt or two in with a 1/2" of space to keep it close when you break it free. Watch the Thrust Washer Take note of how the spring is located on the parking lock link. Larry
No need to drop the pan for a filter. If you have the external filter change it. Dextron III is fine. I drain, Fill, pull the upper trans radiator cooling line. Put 2 tubes into a gallon jug and start the car. The trans will pump out all the old dirty fluid. When you have about 3/4 of a gallon, shut off the car. Fill it back up and start it again with an empty jug. another 3/4. Repeat until the fluid is nice and red/clean. About 4 gallons. Put the trans cooler line back on and properly service the fluid.
Good used KYB set from a self serve yard about $40 each. 2" about. You only need the trailing arm bracket that bolts to the body. It's the part that is longer. Take it easy on the bolts and use PB blaster or some other lube. The nuts are welded to the frame and I've had them break loose. They are also easy to cross thread so make sure they properly thread in.
Good used 2.2 and do the T-Belt and seals and drop it in.
- 3 replies
- head gaskets
- ovrheat
(and 1 more)
Tagged with:
Fronts are easy with the camber adjustment. It will usually bring it in. Rears, i use a smaller dia bolt on the top to allow the camber adjustment. They do sell camber bolts. I've used the lower hub to trailing arm bolts on the top and if you tilt the wheel all the way in you will be close. Outbacks do have a longer steering wheel to rack link and about 1" lift blocks between the cross members and the body. On the Impreza OBS I've lifted you also need the rear trailing arm to body bracket to center the rear wheel in the wheel well.
Check the self-serve yards around Denver. I just put a 99 hatch onto my 2000 OBS. I noticed some hinge differences on the later hatches but I bet if you used your hinge they would bolt up. www.car-part.com is also a good place to check. After 4 yards, I found a hatch that was in very good condition and even the same color. <$100 out the door.
