153
Everything posted by lmdew
There is a connector right at the top of the hatch to the hose that runs to the spray nozzle. I'd start up there. It's the flex boot on the drivers side. Just reaching down in the jack compartment with you hand you should be able to find the washer hose. It goes from clear plastic to black rubber there. If it's off the sprayer you will have to pull the hatch inside panel.
The boot comes off easily it's just on there like a rubber grommet. I little lip of the boot is on both sides of the sheet metal of the car body. Just push it in a little and pull. I used hose off the junk yard car. I only found about 2" hardened trimming it back and it seemed like new. If you use the old hose to pull it through you will not have to remove any interior plastic trim. Sweet.
I replaced my 2000 rear hatch with a 97 hatch this last weekend. Both washer tubes were cracked just below the flex connector between the body and the hatch. Easy fix. Get new hose or go to the yard and pull one. Cut an extra foot off the lower end, which you can reach inside the Jack access panel in the rear. It goes to clear plastic hosing there. Take your new longer tube and attach it to the old cracked tube and pull it down through the body. Connect it in the jack access panel. Put the flex boot back in place. Done
Installed a 97 Hatch on my 2000 today. Worked great, all the electrical plugs joined right up. I found the rear wiper hose cracked on my 2000 and the 97 about 2" from the body to hatch connection. Easy fix with the extra tube. I do have a door Light. I'll have to look to see if the wiring changed. Have a good one! Subaru, plug and play, for the most part. Sweet!
Go to your local you pull and pay and grab a newer set of KYB's off a Forester, complete struts and springs for about 45 each. I watch for them all the time when I'm going through the yards and pull them when I see a good set, even if I don't need them right away.
- 18 replies
- quick struts
- raising
(and 3 more)
Tagged with:
I always check the car for Oil service sticker or paperwork. I've powered them up with a 9v battery but it been so long ago I couldn't tell you what connector pins you need to go to. Do you have the same car? Could swap the dash into your car. Other than that you will need the factory wiring manual to figure out + and - circuit.
To late now, but for future installs you can buy an adapter harness so the stock plug remains for others down the road. Load (Radio) Power -12 VDC constant-memory functions, switched to power the unit and ground. 3 elements necessary in any circuit. I'm sure you know that already but added it for others.
Yes, it runs up the Drivers side of the rear body side of the hatch, then towards the flex hose you see. Best thing you can do is get it into a warm space before you pull the plastic. If the interior is up above 70F and you give the interior plastic time to warm up it will be less likely to break off the clip tabs. If you have access to a self serve parts yard go pull the panels there first so you know how it all comes apart. Then there is the question is it worth it? You could unplug the rear washer pump connector and disable it and never worry about the leak.
The original radiator was leaking at the plastic to aluminum seam on the top. I got a nice all aluminum radiator from Radiator Express $180. The stock 2006 fans did not fit but I had a spare set from an 2000 Impreza that bolted right up. They are a little wider so they are very close to the AC Belt adjustment pulley bracket. They also need a little jumper from the 2006 Forester wiring harness to the Impreza Fans. Here's a link to the radiator: https://www.radiatorexpress.com/product/all/subaru/2006/forester/x/25l-h4/222258/1432593 Very nice. Got it all back together and there is a whine from the front of the engine, AC Condenser, ALT or Power Steering pump were all possibilities. A little more checking and I see the PS pump fluid is full of bubbles. A noise check using my long screw driver to the above listed parts confirmed it was the PS Pump. Well it was fine before the radiator change so I figured it was just sucking air in through the hose. Replacing the spring type clamp with an old style heater hose clamp at the PS pump to reservoir fixed the problem. A day later all the air was out of the fluid and the pump was back to normal.
- 1 reply
- 1
