153
Everything posted by lmdew
Well, I've sold this Outback 2 times now. First to a Co-Worker and then to a Friend. Two weeks ago, it was stolen out of her driveway. Who steals a 98 Outback with 240K on it. Yes it's a Subaru. Anyway, the police recovered it. The oil was way over filled and missing the cap. Battery dead. I charged the battery and changed the oil and filter. Put some gas in it and the 2.2 started right up.I did the 2.5 to 2.2 conversion about 5 years ago. I love those 2.2's. The transmission seems to shift into all but 1st just fine. The clutch pedal feels good and the input fork is moving. There is absolutely no transfer of power from the flywheel to the transmission. No loading of the engine when you let the clutch out with the transmission in gear. The only other time I've seen this was on a 2000 Forester and when I dropped the trans the center hub of the clutch was completely disconnected from the clutch disk. It looked like they downshifted from high speed or were rolling backward and popped the clutch. More then one Mechanic has told me they have changed Subaru clutches with the trans pulled back to the end of the long bottom studs! Is that really possible? With my change of jobs, I have limited time and limited space and the owner has limited money. Just thinking I may be able to get them back on the road in an afternoon. I don't like the idea, but I'd be willing to try. Thanks, Larry
I have good used ones, rust free from CO. $35+ shipping.
- 46 replies
- 3
- knuckle
- snapped bolt
(and 4 more)
Tagged with:
computer ground
lmdew replied to subpoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Car Details? Year and Model? Most of the ECU have a ground wire in the connector but it's always a good idea to have the case ground as well, by bolting it up. -
Check and see if the rear drive shaft is spinning when the front wheels are but the rears are not. I've seen where one of the rear axles had popped out about a 1/2" and the rear drive shaft power was not going anywhere. Installed the rear half shaft into the rear differential properly and problem solved. Pretty quick check at the rear diff, just make sure both half shafts are fully inserted.
Yes and I'm sure there are plenty of them in the self serve yards in Denver. Pull the door triangle trim - forward on the door. It pops off, gently pry it off close to the pins. A painters 3 in 1 tool works great. Remove the Door panel Remove the electrical connector Remove the 3 screws holding the mirror.
Is the starter clicking? Do the headlights work when the starter does Not? Along with what the others have said the starter main contacts are prone to wear. When the main contacts within the starter are not good, no power is getting to the starter motor. When it is NOT working, Read voltage under load - key in the start position at: Battery + to ground Starter + to ground Starter Motor + to ground Make sure all the grounds are clean and tight. One fellow had a pitted ground at the rear engine negative ground wire and his car would not charge. Fixed the ground and it was good as new. He had put in 3 alternators.
Have 4 spare driver side A-arms. Shipped from CO.
- 5 replies
- control arm
- bushing
(and 3 more)
Tagged with:
