153
Everything posted by lmdew
The resistor pack is about an 1" square and about 2" long. There is a electrical connector and 2 screws that you will see on the air ducting under the glove box. Remove the connector and the screws pull it out. Put the new one in. The link shows a nice picture on amazon. https://www.amazon.com/Wells-JA1230-Blower-Motor-Resistor/dp/B000EQO07O/ref=sr_1_3?ie=UTF8&qid=1532083883&sr=8-3&keywords=Subaru+Impreza+fan+resistor
Trans ATF
lmdew replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I've been very happy with Amsoil. -
CV Axle Roll Pin
lmdew replied to Zoltan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yes, sounds like someone drove the pin in when the half shaft was 180 out. The other option is to pop out the half shaft with the stub axle attached. It's held in with a circle clip. Remove the strut to knucle bolts and lower ball joint then use the weight of the hub as a slide hammer and the stub axle should come out. -
Drain > Fill Pull the radiator trans coolant line, I use plastic tubing to run both ends into a gallon jug. Start the Subaru, it will pump out the old nasty trans fluid. When you have about 3/4 of a gallon turn off the engine, empty the jug, fill the trans with another gallon of fluid > Repeat until the fluid going into the jug is clean. It usually takes about 3 gallons. I'm sure it will be much better, then if you really want to improve your trans switch to Amsoil trans fluid. It made a world of difference on my 2002 Impreza with 230K on it.
