153
Everything posted by lmdew
I've always pulled the radiator trans cooler return line and put it into a gallon jug. Fill the trans Start the Car, let it pump a 1/2 gallon out Stop the car, refill the trans and empty the jug Repeat until clean fluid is coming out. Pretty simple and works well. Yes, check the line and make sure it's clamped on well. Check the trans fluid level, COLD then HOT after a good drive.
Since you are in so far, I'd replace the fork and get a new dust boot for the trans. When you put the new fork in put a dab of grease on the pivot point. With the sleeve and new throughout bearing you should be good to go. Have you resealed the air oil breather plate on the back of the block already? If not I'd do that as well.
Charging Help
lmdew replied to ocei77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I helped a fellow fix something close to this. It turned out to be the main battery ground at the transmission to engine starter upper bolt attach point. It was loose, burned and pitted. -
Oil and Filters?
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Nice a + being from WI way back when. -
Oil and Filters?
Ordered my Amsoil today. -
I've had this happen on about 4 manual trans Subaru's. The center viscous coupling will transfer light power, but when power goes to the rear with a disconnected half shaft it goes no where. I do have good half shafts, $20 + Shipping from CO. These are used stock Subaru axles with good used boots. You can pull the strut and hub bolts if there are not frozen and then pull the hub away from the car. Once the inner side is free you can remove the axle from hub.
