153
Everything posted by lmdew
When you first turn the key on, you should hear the fuel pump run for a few seconds to build pressure. If you hear it run, you should have fuel coming out the filter hose. You can always pull the air box off the throttle body and put a cap full of fuel in the throttle. Put it back together, it should start and run for a bit.
Oil and Filters?
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
GD are you running Amsoil and Amsoil filters? What interval do you change them out at? Thanks, Larry -
I've always been a change it ever 3000 miles with a quality oil and filter and check ever gas fill up - $20 or so. How many are running Amsoil is $8 - $12 a quart and the filter is $16. So say $66 for an oil change. Are you running it to 100k for the next oil change? What's your experience? Better half now has a 2006 Forester. Thanks, Larry
I have good front hubs in Colorado. Sometimes the axle CV joint fails internally so the axle shaft is turning but no power is being transmitted to the wheel. Have someone put it in gear while you watch the axle from above and off to the side. Is the axle turning? If so it's most likely the outer CV Joint. Get a Subaru axle. Larry
I've scrapped lots of Subaru's over the years but never thought about what the yards do with non-deployed airbags. I have several passenger and drivers side airbags that I'm going to recycle. I searched the web and found a few options but other than deploying them with 12 volts - 30 feet away and then just sending them through the metal recycle centers not much. Thought I'd ask. Thanks, Larry
If you end up needing one. I have an 07 Legacy Outback CAT. The engine had 42K on it. $200 = Shipping from 80919
- 5 replies
- Catalytic Converter
- 2006 Legacy Catalytic Convert
(and 1 more)
Tagged with:
