153
Everything posted by lmdew
Love the 95 2.2 swaps into a 98 Forester or 96-99 Legacy Outback. I have had a 98 OBS Manual Trans it had 380K on it when I sold it and it's still going strong. I"m now in a 2000 OBS Auto. It has 240K on it. You can't go wrong with this set up and normal maintenance. Under $2000 and you have a great car that will last years! Here's a couple: https://cosprings.craigslist.org/cto/6161214892.html https://cosprings.craigslist.org/cto/6160168054.html
I helped a friend pickup a 2004 Legacy Outback Wagon. PO said the trans was bad. No fluid in the Trans. We go it back to work, cleaned the Trans and added fluid. Sure enough, fluid is running out the trans. It's coming from the front of the filter housing. We shut it off and back off the filter. You can see a hairline crack about the 7 o clock position on the filter housing on the trans. It's about a 3/8" thick casting that the filter screws up to. Very strange. I don't know why that thick casting, part of the transmission case would ever fail. Anyone ever seen this? Thanks, Larry
You can search this form as well. Lots of info here. What's the mileage? I usually do not do the water pump as the Subaru pumps are very good. I'll change the Cam and Crank Seals, Reseal the oil pump and lock tight the cover plate screws, new Gates T-Belt and all the idler pulleys. Gates Kit is good. If it's leaking oil from the rear breather plate, it's a good time to pull the engine and take care of everything while the engine is out.
Depends on the price. If you can get it at the right price and put in a good used engine then, go for it. www.car-part.com will give you a good idea on a used engine. Explain to the fellow that his engine is not going to last long as the lower end bearings are shot. $1000, may be $1500 if its in good condition other than the engine.
I've used Gray RTV on all of them and it's worked well on many engine and transmissions. Clean the surfaces well and then I let it cure 24 hours before I put fluid in an start it up. Most Subaru Valve Covers have there own seal and it goes on dry.
- 9 replies
- Oil Pan Sealant
- Oil Pump Sealant
- (and 7 more)
Thanks, might give it a try. The OBS has 220k on it and the PO had the new clutch go out. NAPA replace the clutch for them and I asked about the shaft free play. They said they checked it. But then when I was driving it, I had a hard time getting into 4th. Not all the time but sometimes. The trans on a Forester that had the center of the clutch go out felt the same. So better to put a new trans in it now.
I picked up a 98 Impreza OBS that needs a new Trans. The search of the local yards turned up several newer trans with the hyd release. I've converted cable to hyd clutch release before, but I don't want to go to that expense again. Is it possible to change the clutch fork and remove the cable bracket from the old trans and bolt it up to the newer trans? Thanks
