lmdew
    153
Everything posted by lmdew
  1. Fixed it on my Daughters 99 Impreza OBS. the short extension on the read O2 Sensor did the trick.
  2. I'd at least open up the timing and get a good visual. What year is it? 96 and later are interference engines and if it goes you will likely bend valves.
  3. Would be nice if http://overdraftautolife.com/2013/08/21/do-it-yourself/ has some interior pics. May be a bit short for someone over 6' tall. Also no kitchen hatch.
  4. http://vintageoverland.com/ I read the article in Popular Mechanics and then went to the website. Thought some of you may enjoy the info.
  5. Check the ground connections. I had one fellow here in town that had installed 4 different used Alt that I had for him. He finally brought the car over for me to look at. As I check the grounds, the main battery ground lead that bolts to the engine block bracket at the starter mount bolt was loose. When I pulled it off the bracket and terminal on the ground wire was all pitted. I changed the battery leads and bracket the problem was fixed. Larry
  6. Yep, do the T-Belt, Cam and Crank Seals and the Oil pump screws on the back and the oring seal. I use Gray RTV to seal the pump to the block. Light coat, and I like to let it set for 24 hours before I start the engine.
  7. If you have any other work that needs too be done on the engine, pull the engine. Other's notes above apply. I've done it both ways and like pulling the engine better.
  8. Gray RTV, just a very thin coat. I always let mine cure for 24 hours after the install.
  9. Drained the oil, yep I could feel chunks inside the pan. I pulled the engine yesterday. Anyone need parts. The yard core charge is $50 so anything over that is fine by me.
  10. Totally different shop in a new location. I use to take used 2.5 DOHC cores up the Rick and Emily at the old CCR. I always enjoyed doing business with them over the years. Great source of engines and information. The new owner seems good, it's just not the same CCR. I assume they are good, time will tell.
  11. All done, replace the clutch and pressure plate as well. An early Birthday present for my Daughter.
  12. Pulled the engine to day after I could push the fork back further by hand. Broken Clutch Fork. Larry
  13. you would have to provide the wiring for it as they plug in right at the sensor.
  14. That's another option, but I did check it when I installed the engine and it was good. No signs of wear.
  15. I had the engine in an out of the Daughters OBS a few months ago. The clutch was pretty much new, good everything else. Yesterday she call, and could not shift into reverse and was having a hard time from 1st to second. Drove up to DEN this morning and I adjusted the clutch cable, there was almost 3/4" of free play. Shifted fine, but I gave her my OBS and brought her's back to COS. By the time I had driven 80 miles the shifting problem was starting to surface again. I adjusted another 1/4" of slake out of the cable. I'm thinking the clutch cable is on the way out, not releasing the pressure on the trans. Trans shifts fine when the engine is off. Anyone ever have a clutch cable do this? Thanks, Larry
