153
Everything posted by lmdew
A fellow in town has a 95 Legacy, Auto. I gave him an Alt to fix his charging problem, it was used but good as far as I know. Gave him another used one, same thing. He stopped over today, good battery voltage 13 volts. I changed a the alt again, no luck. When the car is started battery voltage goes down to 12.5 volts and 12.3 with the light on. Fuses look good, connections clean. Then I noticed the battery light on the dash is on when the key is off. I have never seen this before. Help! Thanks, Larry
98 gt woes
lmdew replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I have two sets of COMTEC H/G for the 2.5 block and 2.2 heads if you need them. I was going to build a high compression motor but have not done it. The 98 Impreza OBS I picked up for my Daughter with a thrown rod took 3 engines to get a good on. You never know with used engines, but over the years and 40+ junk yard engines I've only had 2 that did not work out. Larry -
Timing covers
Good covers and no leaks keep things nice and clean and rust free. -
Much easier to leave the trans in the car! Make sure you keep the TC fully seated in the trans and push it away from the flex plate once all 4 bolts are removed. It will move back about an 1/8" You will have to jack the trans about an 1" and 1/2 to allow the flex plate to clear the cross member. Don't jack on the pan as it will dent.
Yes, your flex plate will bolt right up. The biggest thing is to have a matching EGR. If your current engine has an EGR you need an EGR on the new engine. There are some work around's but since you bought the engine, I'm pretty sure you ensured they should match. Reseal the rear breather plate while the flywheel/flex plate are off with Gray RTV. A good used 95-98 2.2 engine would be a good option.
www.car-part.com check for a yard engine. Your son will still learn a bunch from the engine replacement. There are a bunch of USMB members that rebuild engines full time. I work on older stuff 96-99 Outbacks were I can find a good used 2.2 for $300 and drop it in with new seals, timing belt... for under $500.
Nope, if you don't want it snip the belt. It's AC only. It is recommended to run the AC every month or so to keep the o-rings lubricated and system working. If you have not done that for years, it won't make any difference now. Not much of any MPG change as it's just rotating a belt when the AC is off. No load on the engine.
The alignment pins are often corroded into the trans. I will require you to pry the engine and trans apart. Go easy, start with a thing screwdriver driven between the engine and trans. Work up to a pry bar. Some folks like to drive the pins forward, the passenger side will come out the drivers side will hit the engine block but you can move it half way out of the trans.
Tranny option
No the original one will work fine. -
I've pulled 20+ engines from the you pull yards. Look for: - Car hit hard, you know it was going down the road - Car is in other wise good shape, you know the owner took care of it - Oil, pull the pan plug, the cleaner the oil the better. Put you finger in the drain hole and check the bottom of the pan for metal inside - Engine turns over by hand and compression feels good on all cylinders - Pull a plug or two, good clean burning - Coolant looks good If it passes all those checks pull it. Before you install it: - Reseal the rear breather plate - New Plugs (NGK) and valve cover gaskets - Reseal the Oil Pump and locktite on the rear cover screws - New Subaru Cam and Crank Seals - New Timing belt kit - Make sure the thermostat is a Subaru one and the gasket is good
