153
Everything posted by lmdew
part interchange
lmdew replied to whynot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Subaru are like lego's. Lot's of parts will bolt right on other Subaru's: Brakes Struts Seats A good used 96-99 Outback with the DOHC engine that the Head Gaskets have went out is a great platform and will last a long time. -
Yep, I did the same thing years ago. I love the ability to quickly bleed and flush the brake system. I use Quick disconnect air fittings on my. They seal fluid as well. Nice Post.
- 5 replies
- power bleeder
- brakes
(and 2 more)
Tagged with:
I don't think the 99 Legacy has the plug built in. I just added a hitch to the better half's 2006 Forester and it had the pigtail on the passenger side in the floor. Easy. I used http://www.etrailer.com/ for the Drawtight hitch and wiring. Easy and Fast and a price that could not be beat. Older Legacy's I've seen the tail lights tapped into behind the lights. I'm not a fan of the crimp on wire taps but that is what I see the most.
Give Joel a call or email. http://www.greensyncro.com/ Vanagon Sales - Parts - Upgrades - Restoration - Engine Conversions Working only on 1982-1991 Vanagons, Syncros and Westfalias. Located in Manitou Springs, near Colorado Springs, CO Content copyright 2016. GREENSYNCRO.COM. All rights reserved. Contact us at 719-213-7604, or manitousyncro@gmail.com thanks! I have a ecu from a 2002 Subaru Legacy, $30 shipped.
Sunday, I installed the motor. It started and ran great for about 20 minutes, and then started knocking, sounded like a rod knock. Shut it off, it was the end of the day. Strange it ran just like a Subaru should for 20 min. I had pulled the coil plug and cranked it to get oil through the engine before starting it and then when I did hook the coil up it started and ran great. Monday - Thinking one of the valve keepers may have come off, I pulled the fans, accessory belts and valve covers so I could check the valve keepers and crank it over by hand. - all valve keepers and valve train looked good - I pulled the plugs and turned it over by hand. About every 2 or 3 turn as #1 came up on compression the crank would lock up. I did not force it but it would not turn in the normal rotation with light pressure on my 1/2" ratchet. I'd back up the crank a 1/4 turn and then it would crank right through a couple more rotations of the crank. - Just putting my thumb in the plug tube, all cylinder have compression. When I put the plugs back in, one at a time compression felt good as I turned the engine over. - Everything back together and it's turning over fine, not locking up - I get it pointed out the back of work to drive it to the parking lot. - I start it, it's knocking - A minute or so later, the knock turns into what sounds like valve tick - Another couple of minutes and the tick is gone, it's running fine. - Park it for the night Any ideas what could have caused the Knock, locked up crank when turned by hand and then it goes away? Very strange. Thanks, Larry
Changed the Oil Pan return tube o-ring seal and the Valve Guide Seals. Some said it could not be done and I would not opt to do it again, but I was able to change the valve guide seals without pulling the heads. Installed the Timing belt so I could rotate the cams until there was no tension on the valves. Removed both sets of Rocker Arms Removed the Plugs Put the piston at BDC and put rope down the plug hole to fill they cylinder Rotated the crank to bring the piston up to compress the rope and hold the valve up Used a valve spring removal tool, the one that catches the keepers to remove the valve springs Used a Plug Wire Pliers to remove the old valve guide seals Installed and seated new valve guide seals Now the hard part, compressing the springs and getting the keepers in: I used a tool sold for this purpose, but it was too large for the Subaru Valves. I turned down the pin on the lathe. It worked about 50% of the time. When it didn't work, one Keeper was in the other was out. The last time I did valve with the heads off, I had made a valve spring compressor out of PVC Pipe. A 1 1/2 Tee with a 3/4" piece of PVC about 8" long works well. You can cut a 1/2" notch out of the end that will allow you to insert the keeper while you compress the spring. Motor in on my next free day, I hope this has solved the oil consumption issue. Larry
