153
Everything posted by lmdew
Changed the tail shaft speed sensor, I shifted well and no power light blinking. The owner drove it home, about 30 miles, no problem. The next day, the blinking power light and shifting problems were back. He put in the FWD fuse and it shifts well but the power light is still blinking. I have not had time to pull the codes yet. Ideas?
Yes they are a pain, just did both a front and rear window on a friends 99 Legacy GT. As others have said, the window will tilt in and down in the front and you can guide the rollers past the door. I pull the 3 12mm nuts for the rear guide and get it out of the way. With the window now inside the door and the front guide in the rail, you can guide the real rail onto the rear bearing and up and into the 3 mounts holes. Put the 12mm nuts on lightly. Mount the window to the lower motor guide rail with the 2, 10mm nuts. Put all hardware back on and sung them up. Test and adjust the window as necessary then tighten everything up. Put the door panel back on and grab a cold one or two.
I could have you in a great OBS from Rust Free Colorado for that or much less. I had a 98 OBS with 330K on it when i sold it for $1800 and it's still going strong. I picked up a 2000 OBS that needed engine work for $600 and its doing great. I lifted both my OBS with Forster struts and I like the ride and the look. Pretty easy to do. I have a friend in Sullivan WI, who I set up his Mom with a 98 OBS. If you want to take it for a test drive I'm sure he'd let you. The 95-99 2.2 are pretty rock solid. The newer 2.5 SOHC engines have a slight HG issue, but they leak externally so it's easy to spot and repair. As long as you keep oil and coolant full, you can run them leaking for years. I get 28-30 MPG on my OBS, Timing belt at 105K the first time and I like to do them at 80 to 100K after that. Use NGK copper plugs and wires. Not much else.
When I do the Forster Strut Lift, on the rear struts I put a smaller dia bolt in the top hole and move the hub all the way in against the bolt. I've been running this way for years, no problem. I pull a spare bolt out of my stock of Subaru Bolts, I use the bolt that goes through the trailing arm and into the bottom of the rear hub. If a spacer is needed, I grab the extra strut nut you are not using and put it on the bolt with the small end against the strut and the nut flange out so the 17mm nut for the small dia bolt has a flange to mate up with. Hit a self serve yard and you will have everything you need for a few $. Larry
Yes, Check the spring pin on the end and the seal in the transmission. If they both look in good condition, put the shaft into the transmission the then use the strut/brake mass to push the shaft back in until the sap-ring seats. The other way to do it, would be to pull the spring pin out of the inner half shaft, remove the axle stub shaft, seat it in the trans with a dead blow hammer, make sure it does not pull out and then put the half shaft back on the stub axle and install the roll pin.
A friend at work has a 99 Legacy Outback that Radio memory and interior overhead lights not working. The radio works but looses the time and stations anytime you turn the car off. The overhead lights are not working either. I'm out of town so I don't have access to my computer manuals. Anyone have the FSM for a 1999 Legacy Outback Wagon? Do the lights and radio go through the illumination control box? Thanks Larry
Very rough idle
lmdew replied to rwoerz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Sounds like you have a large fuel leak. Was the injector hard to push in? The o-rings make them a very firm seat. Find out where all the extra fuel is coming from and correct that first. You might also want to change the oil and filter is the oil has fuel in it.
