153
Everything posted by lmdew
Put the FWD fuse in and see if it changes. Sounds like you are in full time 4wd. The C-duty is not releasing the rear drive shafts in a sharp turn. Search torque bind. Did you double check the transmission connectors on top of the trans? Did you jack up the trans by the pan and may be dented it in? Is the trans light blinking 16 times when you start? Read the trans codes or have them read.
Do it when the engine is cold. The preformed lines are nice, but you can get by with straight hose, just make sure you don't kink it. Remove the airbox Drivers side is pretty easy, just remove the clams and hose and replace The passenger side is a little harder access but it can be done. Fill the overflow bottle to the proper level.
I was doing a 99 2.5 to 2.2 swap and need an EGR line. I have several, but they all seem that the threaded fitting is to long. The line does not tighten up against the head before the fitting gets tight. Is there a difference in these lines? When I match the old cut one up it is about an 1/8" shorter, so it seems that there is a difference in the years. Thanks, Larry
When you bleed the brakes, you should not let the brake go down further than it normally does. Putting a 2x4 on the floor usually keeps it in a safe zone. If you take it all the way to the floor, the piston is working in an area of the cylinder that may have built up crud and it can take out the seal. I'd try bleeding it again. If you pump the brakes do you get a better feel? Then air in the system.
- 2 replies
- master cylinder
- brakes
(and 1 more)
Tagged with:
2.5 to 2.2 Swap
lmdew replied to xyzb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You can tap the trany for an heli coil. The hole is the correct size for the 14mm stud. I've done several this way. You can do it after the engine is in. I've worked from the bottom. -
2.5 to 2.2 Swap
The 99 canister is in the back of the car. Just loop the 95 lines hooking them together. It works well if you put the larger line over the smaller one and just make them u-turn at the hard lines. You only need about 2" of vac line to do it. -
The pulley should always move, if it sticks when you tighten it it's not assembled correctly.
- 32 replies
- 1
- head gasket
- oil pan gasket
(and 1 more)
Tagged with:
yes, it sounds like a water pump leak. The water pump is driven by the timing belt, so depending on the milage you may be do for a timing belt and seals. Search here or check you tube, there is lots of good information available. Overheating a Subaru engine is bad! Hopefully you have not done major damage. Find a good Subaru Mechanic or USMB member close by to help you out.
