153
Everything posted by lmdew
I just picked up a 97 OBS project - 281K - Clutch was totally out, the center had broken out of the disk. A cheap clutch for sure - I put a good clutch in, the trans shifts fine, up and down but will not go into 4th. I have not checked the linkage yet. - The Trans input shaft did have a little play, but not bad for 281K I'm thinking a used trans,but thought I'd ask. Thanks, Larry
Exhaust studs
lmdew replied to xdeadeye1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Dealer or junk yard. I often pull good ones in rust free CO. In OH they are most likely all like yours. -
Brakes
lmdew replied to briankk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The half shaft slips into the Knuckle. Brake caliper, Brake Hose, Backing Plate, Hub and E-brake cable will do the trick. -
5MT wont fit
lmdew replied to Aluxes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You can put a threaded insert in the lower starter hole and put a bolt in. -
Back probed the plug 11.5 volts on both sided of the control coil, = missing ground 11.5 volts on the input side of the fuel pump switched contact. I hit the yard today and got a couple of Subaru fuel pump relays, newer ones and plug one in. It started right up. Hopefully it is a solid fix. I believe the relay did it. 2nd day in a row with many start and stop cycles, has worked each time.
Yep, Load, Ground, Power. I"m going to get my meter out today and take some voltage readings under load. I also remembered the PO had bypassed the ignition SW with 3 on off switched which I removed and put back on an Subaru Ignition SW so I'll double check that as well. The connector looks clean and contacts are in good condition. Thanks Larry
I know from previous post the relay ground is controlled by the computer. This one is strange works fine some times and others not. Well, I thought I had it, I swapped the heater fan relay and fuel pump relay and the fuel pump worked just fine yesterday. I went to start it this morning and it would not start. I dropped the kick panel, Computer and just moved the relay and it started and ran fine for 3 hours. I stopped for gas about an hour into the trip and it started right back up. Now sitting in the driveway for a while, I was cleaning it and then went to start it, no joy. I removed and jumped the relay and it runs fine. Wiring or Computer? Anyone have the wiring manual or a good way to check this? Looks like you'd have to drop the complete dash out to really get at all the wiring. Thanks, Larry
You need to find the source of the noise. Changing the length of the strut put your CV joints in a new spot, but if they were in good condition that should be OK. Did you make sure the top strut mount was tight? I've swapped struts where you need a thick washer on top of the strut mount to take up the added length of the top strut mount. Otherwise the nut runs out of threads and you still have movement of the top strut mount plate.
