Everything posted by lmdew
2005 Impreza RS Wagon Low Beams very dim
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplaced the Low Beam lamps, it's better. Happy New Year!
Metal parts that came out with my oil drain plug?
lmdew replied to dburton97128's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNothing in the engine that I know of looks like that. I'd flush out the pan with some diesel fuel, let it drain well. Fill with new oil and run it for a bit. you could also cut open the old filter and see what's in it. Larry
All the headlights High and Low are working, the fuses are good. The low beams are very dim, are they different from the daytime headlights? Thanks
Blower Motor Mystery
lmdew replied to Imprezel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like it's time for a new motor. The brushes are most likely worn out.
2000 Impreza 2.2 automatic engine quit running
lmdew replied to buzzcon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo easy way to tell if the valves are bent other than putting a new T-belt on. Get it timed correctly with a new belt. Turn the engine over by hand to make sure you have not damaged anything to bad. If it turns free start it up. If it's running well, a valve may still have a slight bend. Go back to the exhaust and put a dollar bill with in a half inch of the exhaust pipe. If it ever sucks back to the exhaust pipe you have a bent valve most likely.
Leaky Passanger Cam Seal After Replacement
lmdew replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUse some green sotchbright to cleand the cam shaft and OD of the seal.
2005 Impreza RS Wagon- low idle
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, I've had good results with both if used correctly. And yes, as I said a tune up is on the schedule as well as a good inspection the engine.
I picked up a 2005 Impreza from a coworker and it's going to my brother's better half. Auto 129K Runs nice, but has a low idle, showing 300 RPM on the gauge in D or N. I plan on running some Seafoam through it Changing the Plugs and see what they look like I've added some lucas fuel conditioner and Shell premium Idle control valve? I'm just starting on this one Thanks, Larry
2003 Baja Tach dead
I pulled the dash today, thinking it might be a loose screw. No such luck, a large circuit board and everything is soldered in. Any ideas other than getting a replacement cluster? I did not see any problems with the circuits. Everything but the Tach works. Thanks, Larry
99Outback, has oil leak
lmdew replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are rubber gaskets, installed dry. Make sure you use a 6 point socket or wrench. Some of the bolts are a bugger to get out. Every once in awhile I have to drop the exhaust and jack the engine to get the back bolts if they were rounded off or very tight. Amazon, Felpro kits are pretty good and priced right. If the plugs have not been done in awhile, it's a good time to put in a new set of NKG copper core plugs and wires if you need them. Subaru or NGK on the wires as well.
99 Legacy Outback ej25 Issues
lmdew replied to ratch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you need a replacement engine go with a 95 2.2 with ERG. Plug and Play for the most part.
02 forester--put in engine forn OB wagon?
lmdew replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEmily, you and Rick and the rest of the Gang at CCR are the best. Thanks for taking the time to post to the USMB, I know you have a lot going on. Larry
99 Legacy Outback Key off - Power Still On?
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks, Larry
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, it was not the usual things. The Dash light ABS was on. If it comes back, I'll dig under the dash and find the main power relay - key on, power on relay. Thanks, Larry
Retiring '97 Legacy
lmdew replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, motor is plug and play. Save the motor and any other good parts you may want. Scrap the rest about $250 or so for the weight of the metal.
A 99 Legacy Outback 2.2 swap I did awhile back, started draining the Battery. The new owner went to Autozone and they sold him an Alt. He also got a new Walmart battery. Power was still draining, the ABS light .... I removed the Autozone Alt and installed a Subaru Alt. I charged the Battery It started and stopped just fine many times. All power was removed each time I shut it off. I think the main relay may have been sticking, all though I've never seen that before. I looked under the dash, lower panel removed. I did not see the relays, where are they on a 99? Thanks Larry
bad knock
lmdew replied to legacy603's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got a 2003 that sounded like a bad rod knock and it was the idler gear hitting the water pump. The inner and outer race if the toothed Idler were there but no ball bearings. Worst one I've seen that was still running.
95 2.2 missing on #4
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXInjector! I pulled # 4 today and it was a red injector I have never seen. Instead of the normal metal end it was plastic. I put in a red Subaru metal end injector, NO MORE Cell and it's running better. I'll swap out all 4 injectors and the fuel rails in the next day or two. I'm sure it will be a good Subaru 2.2 again. Thanks, Larry
Thread Chaser for Head Bolt
lmdew replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGrab a spare bolt from a yard and file or grind a v notch down the length of the threads, you know have a backyard thread chaser.
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo the plug is not fouling. I have lots of injectors, I'll put one in and see if that solves the problem. Compression test if I can fine my tester. Thanks, Larry
I got a used 95 2.2 with 57K on it from a yard. I paid $850 for it, way more than the YPAP motors I usually get, but hey with 57K on it I figured it was worth it. Well, It's been nothing but problems. - First it would not start, bad Crank Sensor - easy fix. - It starts but is not running smooth, P0302 & P0304 so I figure a bad coil. I put a good Subaru coil in but its still missing - Pull the Plugs, #4 is oil soaked. I call the yard, they call the yard they got the motor from. They say we pickle the motors when we pull them. - Today I flushed the cylinders with jet fuel. I pulled the plugs, filled the cylinder with jet fuel and let it soak a few minutes. I rotated it over by hand with the plugs still out and then with the starter to get all the fuel out. - Put the plugs back in and rotated it by hand to make sure it was not locked up - Started right up and was running better but still missing - P0304, flashing CEL. The code will clear, but comes back soon. The Injector is snapping well, so I don't think it's fuel I'm about ready to pull the engine and get a refund. Anything else, worth checking before I pull it? Thanks, Larry Back to the UPAP for motors.
Happy Thanksgiving!
Happy Thanksgiving to all USMB folks. - Thanks for the Great USMB - I'm thankful I can still pull engines and work on Subaru's for Fun Larry
Extremely Stuck Valve Cover Bolts - 96 OBS
lmdew replied to jmoss5723's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf they are that messed up, you could drill off the heads of the bolt and then grab the body of the bolt once you have the valve covers off. you may have to drop the exhaust and remove the mount bolts and pitch stopper to raise the engine enough.
96 impreza L suspension upgrade
lmdew replied to Trailcutr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXForester or Outback struts and springs will give you what you want. Find a good used set of KYB complete struts and springs. To center the rear wheels, you need the trailing arm mounting bracket that goes up to the frame. To correct camber, I've used a second set of rear trailing arm bolts in the top strut hole. It allows you to tip the hub in about an 1/8" and that is just about perfect. I watch for the KYB at the self-serve yards and grab them when I see them.
1997 Outback AT OIL TEMP help appreciated
lmdew replied to mattsoft1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe two large gray plugs on top of the trans just behind the engine. If you search here for torque bind you will find lot's of info. You can pull the trans tail shaft if it is the C-Duty that's bad.
- 8 replies
- 1997
- Legacy
- Outback
- AT OIL TEMP
Tagged with:
