153
Everything posted by lmdew
How old is the gas in the tank? If you do not drive this Subaru very often, you may just have old gas with more moisture collected in it. You can do diagnostics on the car, you have to read up on it. Plug the green connector together under the dash and meet the drive requirements. The IAC controls the idle The TPS sends the shift down signal to the trans. I'd get at least a full tank or two on 91 Octane gas through it with some Sea Foam treatment before you start changing parts. Subaru or NGK Plug wires Copper core NGK Plugs would be the recommended parts.
Throttle Cables, loosen the 2 12mm nuts, run the back one completely off until you can slide it out of the bracket. You can now bring the cable around to line it up with the slot in the throttle cam and remove them. There is a metal tab on the bottom of the cam that you have to slide the cable past. Yes, you can swap the lines, it's pretty time consuming as you need the valves associated with the system as well as the electrical harness. It can all be swapped, just make sure you route the harness the same as there is not much room between the engine and the harness when you bolt the intake back up.
I have my Subaru parked at work in Colorado Springs and the Rabbits have crawled up on top of the engine and eaten the wires. Missing on 2&4. Plug wires have been changed, so I'm going to look closer at the coil wires. Lots of grass and bushes around, I don't know why they like to get up on the top of the engine. Crazy!
