153
Everything posted by lmdew
Cleaned a the connectors. I tried slaving in the old Trans switch, no change. I pulled the shifter apart and could see the switch. The shift lever was moving too far FWD and the SW opened again. Pull back on the shifter and it works as it should. Engine is running well. I just need to find a CAT to stop the exhaust leak.
Never throw away/recycle Subaru Parts, you will miss them! New 98 has a hole in the CAT. I recycled 4 of them a year ago and now I need one! Anyone have one around? Second, the Key is stuck in the ignition. It will not come out. With the old trans it was fine. I think that switch is in the shifter and not part of the transmission so I don't know what would have caused it. Troubleshooting to do. The engine was dirty as can be. Headed to the car wash with degreaser. It's much cleaner now but developed a stumble. I put the proper NGK plug wires on it as it still had the DOHC 2.5 wires. I may just let it dry out while I'm off on Holiday for 2 weeks. Time to clean the garage!
I picked up a 98 Legacy Outback with an Auto Transmission. There was a ton of play in the CV axles and it was rolling in park. Turns out the front differential retainer ring case was cracked. Sticking out 1/4 on the bottom. I've never seen that before. It has a 2.2 swapped into it already. Single port exhaust so I'm guessing 1996 - 99. Anyone know the transmission interchange years/models off the top of your head? I'll get the trans # to verify once it's out. Thanks, Larry
I picked up a 06 Impreza OBS 2.5, Manual Trans. The car made a Brrrrr sound when first taking off or letting off the gas. Other than that the clutch and trans seemed fine. I pulled the trans today and the Fly Wheel is the two piece version. Not the solid. I think they call them dual mass? Can the Dual Mass fly wheels be surfaced. I thought I had a spare solid fly wheel but I could not find it in stock. Get the original surfaced? Buy a new solid fly wheel? Thanks Larry
It's the trailing arm bracket that is longer. The arms are the same size. At least from the Forester to an Impreza.
- 1 reply
- 1
Sent PM and text. Happy to help!
I got the harness plugged in today. Everything works but the radio. The radio will power up, for a minute or so the speakers work but then the speakers go dead? I could not find any aftermarket componets under the seat. I tried several radios, they all do the same thing. There are 4 wires coming off the large white plug that I believe go to the cigarette lighter. Black, purple, orange/white, yellow/black. The harness was off a 2006. The Forester is a 2004, but Subaru told me they use the same panels. Off to the yard Wed! Any thoughts?
Manual Controls, two cables one going to each side of the airbox. Good News, there are two connectors and a short 12" wire harness. The connectors are right above the airbag control ECU. Hard to see but there. Subaru parts told me 03 - 08 used the same heater control unit. I pulled one out of an 06 today. We'lll see!
What does Subaru immobilizer do? An engine immobiliser is an electronic device which is fitted to the engine, preventing it from starting without using the correct key. When the key is inserted into the cylinder, a vehicle ID code is transmitted to the body integrated unit, which compares it to the code it has been registered with. Bunch of links on a Google search. Too new for me!
