153
Everything posted by lmdew
Most likely NO. I've had them spin many times, never had damage, as long as it was timed right before it was turned by the crank.
- 6 replies
- Timing Belt
- EJ22E
(and 1 more)
Tagged with:
I believe that stub shaft is held in with a circle spring clip. You could try a pry bar between the inner CV Joint and trans, or put the axle nut back on and then use the strut/rotor as a slide hammer and try to pop it out. you may pull the inner CV joint apart if it's spring clip pops first. I've done it both ways at the yards.
The pump will cycle on for a few seconds when you first turn the key on and then turn off, this is normal operation. If the fuse is good, you should have power to the pump. Your pump may be going bad, pulling more amps than normal. Worked off the battery cause of the high CCA. Search fuel pump, there was just a thread on this last week or two. Turned out to be a bad pump. Fixed with a good used Subaru pump from the yard. Your meter can lie to you if you are just checking voltage. Check out the Load Pro at www.brighterideas.com Larry
Always good to read the owners manual, the FWD fuse info is in there. Half shafts are pretty easy to change as long as the splines in the hub are not rusted in. Loosen the axle nut Pin punch the top strut bolt for alignment Remove the top lower strut mount bolt Loosen the lower bolt Remove the inner half shaft roll pin and slide it off the trans shaft Remove it from the hub. Reinstall in the reverse order
You will find 4 or 5 bulbs in the unit. You have to carefully pull off the rear circuit board. The bulb holders are 1/4 turn and come out easy. You can work the green plastic cover off the old bulb and reuse it. To make the mini bulbs the same length, grab a ball point pen and pull the ink tube out. Cut the empty upper end to the length you need and feed the mini bulb wires through and into the old socket. Trim the excess wire.
