153
Everything posted by lmdew
no on he neutral SW.
- 4 replies
- 95 legacy wagon dies random
- neutral safety switch
(and 1 more)
Tagged with:
The two fuses close to the links should remove all power down stream. I'd pull the fuse box and remove the cover on the bottom to see if you have a short.
- 11 replies
- 1990legacy
- fusible link
(and 5 more)
Tagged with:
A fiend has a 96 Legacy Auto I sold to him years ago. The Auto Trans just started acting up, vibration during acceleration and the Parking pawl is no longer holding. 200K miles or so. So he is looking for a good Subaru Mechanic in Wisconsin who will not take him to the cleaners. I guess the rear clutch extension shaft could have sheared off or the parking pawl broke. Used Trans may be the way to go. Lmdew2@gmail.com Thanks, Larry
Put a couple of jumper wires on the fuel pump plug so you can watch voltage as it runs. Running for a few seconds when the key is on and then turning off is normal. You may also want to tee in a pressure gauge in the engine fuel line to watch the pressure. I've seen many pumps work on the start cycle but then fail to run all the time.
As long as the battery has been disconnected for awhile, Airbags will be OK Any Torx set should be fine. You can just drop the steering wheel down if you want, no need to remove the column. I'd hit the Junk Yard and pull a heater core and any lights you want. Cheaper and you get to practice on a car you don't care much about.
Yes the piston has to come all the way out. Put the new seal over the piston, not in the grove but down by the bottom end of the piston. Extend the seal and work it into the caliper grove. once in push the piston in. I've also had luck putting the seal into the caliper and then using low pressure air to pop the seal up onto the piston.
reseal Oil Seperator, Subaru metal ones are $12 0r so. locktite oil pump rear cover plate, new o-ring & reseal Cam & crank Seals New ngk plugs New valve cover gaskets
- 25 replies
- engine build
- EJ22
(and 1 more)
Tagged with:
Check the voltage under load! Both leads to the battery, check Voltage Have some one try to start, check Voltage, you should see a voltage drop under load Move the positive lead to the Starter terminal, check voltage Have someone try to start the car, what's the voltage drop Move to the positive going to the starter motor, down stream of the starter contacts - repeat. Record the voltage readings, this will tell you where the problem lies. Some great electrical training at: www.brighterideas.com Load Pro tool is great, but if you can check the system loaded and connected you can get by without the Load Pro.
