153
Everything posted by lmdew
Still have not listed the codes. Any auto parts store will read them for free. Codes Clear Codes (disconnect the battery for an hour Drive, if the CEL comes back on get the code Anything less and you are loading the parts cannon!
- 31 replies
- MAF
- Timing jump
(and 1 more)
Tagged with:
Timing ?
lmdew replied to Dinky26's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Tick mark on the back crank tooth lines up with the tic mark on the top of the oil pump cover! -
If the old one was broken, did you ask yourself Why? Is the pressure plate stuck? Bad pivot for the fork?
- 8 replies
- clutch change
- 5 speed
(and 2 more)
Tagged with:
HG most likely. The high pressure is combustion gas leaking into the coolant. bubbles in the overflow tank. I picked up a 98 that blew coolant about 30' in the air when I started the engine to finishing filling the radiator.
- 13 replies
- heating and cooling
- overheating
(and 1 more)
Tagged with:
Cable off the cam? Pull the air intake and make sure the throttle plate is completely closed. Have someone push on the gas pedal and you can watch it move. Full closed to full open.
- 6 replies
- LGT
- Knock sensor
(and 1 more)
Tagged with:
Sold the last like new one for $60 shipped. I love Colorado rust free cars!
- 6 replies
- fuel filler neck
- 99 Legacy GT
(and 2 more)
Tagged with:
