153
Everything posted by lmdew
Hi! from January @ Heuberger Motors
lmdew replied to HeubergerMotors's topic in Meet n' Greet. Your USMB Welcome Center
25% off online parts orders are nice! Sorry Ryan left parts, he was Great. Posting older Subaru's or ones that need some work here before they go to auction would be Supper! Thanks, Larry -
Has to be easy to use otherwise the Owner won't. If the SOB is planning the theft they may be watching, so if the Owner goes into the trunk each time the enter or leave the car, that would give it away. Drive an old car and leave it open, if they take it, just go get another with all the insurance money you have saved
Oil Pan Leak
lmdew replied to palfer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yes, Subaru parts! -
Oil Pan Leak
Subaru Parts? The metal crush gasket should seal fine. If not I'd pull the plug and check the hole for defects, dented, cracked... Pretty thick metal so you could sand flat if needed. -
Have a 2002 LEGACY OUTBACK, the hood and roof were significantly crazed and some rust showing through. A co-worker paints on the side. I dropped the headliner So I could pull the roof rack. 80 nuts and bolts later it was off. I could see runt under the primer inside the car. The fellow who did the paint for me said there was rust under the primer on the outside as well. So it looks like Subaru had a paint process problem that allowed some surface rust to form be for the car was painted. Looks nice $400 just in materials!
Pretty much bolt in. You will need the trailing arm to body bracket from the Forester or Legacy Outback so the wheel goes aft about 1/2" and is centered in the cutout. Also grab the lower aft trailing arm to hub bolt and use it for the top strut to hub bolt. The smaller dia, allows you to correct the camber by tilting the tire in all the way. You may need to change the top mount over from your old strut.
Yes that's the knock sensor. The ECU will flag it and retard the timing, less power, bad gas mileage. Make sure the knock sensor is installed correctly and the wire leads are not tangled. Its a tight area, sometimes it's worth unbolting the throttle body (4 bolts).
